Is the Neo Socket Truly a Fuel Saving Device?
In summary, the Neo Socket Automotive Power Factor Corrector is a new electrical device that claims to increase the efficiency of AC electrical devices in a car by storing wasted energy in capacitors. However, it is uncertain if it can actually save fuel used by the internal combustion engine. It is also unclear if all car electrical components use DC power or if some use AC power. This device is likely a scam and car electrical systems mainly use DC power.
Bararontok
298
There is this new electrical device called the Neo Socket Automotive Power Factor Corrector supposedly made by the Japanese company Miraizu that can be plugged into an automotive lighter's electrical socket which can increase the power factor of the AC electrical devices of a car. Power factor is the efficiency of AC electrical circuits which normally use components like inductors and capacitors that discharge and waste some of the energy delivered to them. And power factor correctors are devices that store up the wasted energy briefly in capacitors before sending the energy back to the electrical circuit.
The theory of power factor correction is true and it can indeed increase the efficiency of AC electrical devices but does it really save the amount of fuel used by the internal combustion engine of a car? When the engine is running, the alternator is kept operating at a constant speed to generate a constant power output by a speed control differential gear which automatically lowers the gear on the shaft of the alternator as the engine speed increases so that the speed of the alternator remains constant. This means that even as the electricity wasted by the AC power components is saved, the alternator will still be running at the same speed to give the same power output and still use the same amount of power from the engine. So can using a power factor corrector really save the fuel used by an automobile engine? And is the car battery using an inverter to deliver AC power to the electrical components or can some of the car's electrical components use DC power as well? Because if the battery is connected to an inverter, then a power factor corrector can reduce the power consumption of the battery, allowing the battery to operate for longer periods of time without needing to be charged by the alternator, therefore the alternator can remain turned off for longer periods of time thus reducing the amount of fuel spent by the engine to run the alternator.
Could you let us have a list of the "AC devices of a car", perhaps, and the amount of power they consume (efficiently or inefficiently)?
I can't make up my mind whether or not this is Spam ?
That is why this question was posted so that the consultants on this site can provide information that the thread originator cannot because the originator of the thread is not sure if there are any electronic devices in the automobile that use AC power or if they all use DC power.
It's a scam. Car electrical systems are DC.
So that means that every appliance in the automobile such as the lights, air conditioner, vent fans, CD player, and radio all use DC power?
Yes.
The only caveat is that you can plug an AC inverter into the DC power jack in a car, and generate AC power for external devices that you normally plug into the AC Mains wall sockets in your home. But that's not what this device is used for. This device is just a capacitor, and claims to improve some engine efficiency. Scam.
1. What is the Neo Socket and how does it work?
The Neo Socket is a device that claims to improve fuel efficiency in vehicles by using advanced technology to optimize the flow of electricity from the car's battery to the engine. It is plugged into the car's cigarette lighter socket and supposedly reduces resistance and stabilizes the electrical current, resulting in better fuel consumption.
2. Is there any scientific evidence to support the claims of the Neo Socket?
There is currently no scientific research or evidence to back up the claims of the Neo Socket. Many independent studies have found that the device does not improve fuel efficiency and some have even reported a decrease in performance. It is important to rely on reputable sources and scientific evidence when evaluating the effectiveness of such products.
3. Can the Neo Socket be used in any type of vehicle?
Yes, the Neo Socket is advertised as being compatible with all types of vehicles, including cars, trucks, and motorcycles. However, its effectiveness may vary depending on the make and model of the vehicle. It is always recommended to consult with a mechanic or do thorough research before purchasing any aftermarket devices for your vehicle.
4. How long does the Neo Socket last and does it need to be replaced?
The lifespan of the Neo Socket is not specified by the manufacturer. Some users have reported that the device stopped working after a few months, while others have claimed it lasted for years. However, considering the lack of scientific evidence for its effectiveness, it is unlikely that the Neo Socket will have a significant long-term impact on fuel efficiency. It may need to be replaced if it stops working or if the car's electrical system is upgraded.
5. Is the Neo Socket safe for my vehicle and does it have any potential risks?
The Neo Socket is generally considered safe for use in vehicles. However, there have been reports of the device causing electrical issues and even damaging the car's battery. Additionally, some experts have raised concerns about the potential risk of fire due to increased resistance in the car's electrical system. It is important to carefully follow the instructions and to monitor the performance of your vehicle after using the Neo Socket.
  • Electrical Engineering
