B Is Space an Object Capable of Bending?
  • B
  • Thread starter Thread starter AishaGirl
    Universe
The discussion centers on the nature of space and whether it can be considered an object capable of bending. Participants argue that space is not a tangible substance but rather a conceptual framework that describes relationships between mass and energy. The bending of space is described as a shorthand for the geometric effects of mass on spacetime, rather than a physical alteration of space itself. Philosophical implications arise, questioning whether space exists independently of objects, but these inquiries are deemed outside the scope of scientific discussion. Ultimately, the conversation highlights the complexities of understanding spacetime within both scientific and philosophical contexts.
AishaGirl
What I don't understand about the universe is empty space must be made of some kind of material or substance because stars and other large bodies, in fact anything with mass can bend space then it must be made of something which has the capability to bend and be distorted.
How can space bend if space is not a thing? I don't understand.
Space news on Phys.org
It does not necessarily need to be made of anything. Light can be bent as a result of strong gravitational fields, which is what happens in the case of black holes.
You are having a very common misunderstanding, based on pop-sci presentations. Space is not a thing and does not actually bend or warp or do any of those things. What DOES happen is that things travel on what are called "geodesics", which are straight lines in Riemann Geometry, which is the geometry that describes space-time. When looked at from the point of view of Euclidean Geometry, those same lines are "bent" or "curved". So we SAY that heavy objects like planets "bend" spacetime but that's just shorthand for what I just said.
Likes QuantumQuest
As phinds said, Space isn't bending. That's just a common way to describe it because the effect is somewhat similar to what happens if you bend the surface of an object. What happens is that the geometry of spacetime changes in the presence of mass or energy.
Still, your question has merit and the question of whether space (or spacetime) is a "thing" depends upon your definition of what a "thing" is. This gets into metaphysics and there's no consensus that I know of at this time.
Space is like a force. Is a force made of some kind of material? I don't know the fact is that it is a measurable quantity that has effects on things in the nature. We cannot see a force but only its effect ad we cannot see the space but the extension of the space ...
I don't know if this clarify, sometimes speaking on these thin interpretations I get confused ...
Ssnow
This may be too philosophical a question for PF, because you can't resolve it to one way or the other with any experimental data... Ernst Mach said something along the lines "Space is a mental abstraction that we construct to describe relationships between objects", which clearly implies a view that without objects like planets, stars, dust clouds, etc. there is no space. Then again, an "empty" space can contain energy in the form of gravitational waves, but you can't measure that energy without also having matter present (because any measuring instrument, not to mention a person using it, must necessarily be made of matter).
Likes Drakkith
I think that's certainly a valid point.
AishaGirl, I don't mean to shut down your question, but the fact is that this falls more into philosophy than science and we don't usually allow philosophy here at PF. If you'd like to understand how science models spacetime and all the rules we use to predict things within it, feel free to ask. But the question of "is space an object" just cannot be answered at this time.
Thread locked.
