Is the Work Calculation for Overcoming Friction Correct?
6 replies · 2K views · last reply
Brittykitty
A force of 52 N is applied to a 12 kg mass resting on a bench where the force of sliding friction is 15 N. The work done in overcoming friction while moving the object 24 m is
w=fd
w=(37N)(24m)
w=888J
Does this procedure seem correct ? :) Thank you!
No. You have calculated the net force and net (total) work done on the object. The total work done on the object includes the work done by the applied 52 N force, and the work done by the friction force. The work done to overcome friction is the work necessary to keep the object moving at constant velocity.
What formula would I use to find the work done to overcome friction? I sort of understand but am still a bit confused
The work done to overcome friction while moving the block 24 m is the negative of the work done by friction while moving the block 24 m.
