MHB Is there a formula for finding the perimeter of a triangle with known vertices?
  • Thread starter Thread starter mathdad
    Triangle
To find the perimeter of triangle ABC with vertices A(1, 1), B(9, 3), and C(3, 5), the distance formula is used to calculate the lengths of each side, which are then summed. For the triangle formed by the midpoints of the sides, the midpoints of AB, BC, and CA must be calculated, followed by applying the same distance formula to find that perimeter. The ratio of the two perimeters can be expressed as r = (perimeter part 1)/(perimeter part 2). The Triangle Midpoint Theorem provides a geometric solution for the ratio without needing to compute the perimeters directly. The discussion concludes with a reference to previously posted questions on the same topic, indicating progress in understanding.
mathdad
The vertices of triangle ABC are A(1, 1), B(9, 3), and C(3, 5).
1. Find the perimeter of triangle ABC.
I must use the distance formula for points to find the individual lengths. I then must add all 3 lengths to find the perimeter. Correct?
2. Find the perimeter of the triangle that is formed by joining the midpoints of the three sides of triangle ABC.
I MUST find the midpoint of AB, BC, and BC. I then repeat the same steps for part 1 above. Correct?
3. Compute the ratio of the perimeter on part 1 to the perimeter in part b.
Let r = ratio
Is this what I must solve for part 3?
4. What theorem from geometry provides the answer for part 3 without using the results in part 1 and 2.
I need help with part 4.
Mathematics news on Phys.org
4. The Triangle Midpoint theorem.
You may wish to review these threads, as they deal with the same triangle and perimeter:
  • https://mathhelpboards.com/pre-calculus-21/triangle-abc-22202.html
  • https://mathhelpboards.com/pre-calculus-21/perimeter-triangle-abc-21551.html
  • https://mathhelpboards.com/pre-calculus-21/perimeter-triangle-abc-21111.html
  • http://mathhelpboards.com/pre-calculus-21/triangle-abc-22202.html
  • http://mathhelpboards.com/pre-calculus-21/perimeter-triangle-abc-21551.html
  • http://mathhelpboards.com/pre-calculus-21/perimeter-triangle-abc-21111.html
I forgot that I had posted the same question some time ago. Good. I can move on in the textbook.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
