Is there a quicker way to solve this projectile problem?
  • Thread starter Thread starter Jahnavi
    Projectile
The discussion centers on finding a quicker method to solve a projectile motion problem involving differential equations (DE). The original solution took too long, prompting inquiries about simplifying the approach by focusing on horizontal motion and viscous forces. Participants agree that while calculus is necessary, the DE can be solved relatively quickly once familiar with it. They emphasize that the linear nature of the drag force simplifies the problem, allowing for separation of motion components. Overall, a simpler solution without calculus seems unlikely, and the DE approach remains the most efficient method.
Jahnavi
I solved this problem and got the correct answer 108 m . But I had to solve a DE . This question is from a test where we get around 1 minute to solve a problem . I took half an hour to solve it :wideeyed: .
It looks like a subjective type problem .
I am just curious as to whether there is a quicker/smarter way to find one of the options .
What if you considered just the horizontal motion and the viscous force acting on the horizontal component of the velocity? That way, it still needs a differential equation, but only in one dimension. ## \\ ## It's a very simple D.E. that takes at most 2 minutes to solve for ## v(t) ## and then you can integrate ## v(t) ## from ## t=0 ## to ## t=10 ##.## \\ ## Editing: Yes, I get ## s=108 ## m also. ## \\ ## And note: They make it easy by making ## m=1 \, kg ##, so that ## a=\frac{dv}{dt}=\frac{F}{m}=\frac{-.2v}{1}=-.2 v ##. ## \\ ## Question: Is this the D.E. that you used, or did you try to include the vertical motion?
Likes Jahnavi and cnh1995
I did the same :smile:
Yes !
Likes Charles Link
Yes !
The first time you see that D.E. it might take 15 minutes or more to solve, but that is one that I think I have seen hundreds of times, and it is a simple matter to write: ## \frac{dv}{v}=-\lambda \, dt ## ==>> ## \ln| v|=-\lambda t +C ## so that ## v(t)=v_o e^{- \lambda t} ##. The first several times it probably took me a few minutes or longer...
Likes Jahnavi
I can see , you are trying to make me feel better :biggrin: .
Nevertheless , my intent of posting this question was to know if some of the options could be eliminated and correct answer could be chosen without employing calculus .
I don't think there is any way besides calculus, but the calculus solution, including the solution of the D.E., and integrating ## v(t) ## is very quick=quick enough that if you spent a minute or two looking for something simpler, I think most likely you would come up empty. I don't see a simpler solution...
Likes Jahnavi
Fine, but you first have to know or discover that it is ok to treat motion components separately for linear drag. For any other function of velocity, the drag due to the overall motion has to be found, then the component of interest taken.
Likes Jahnavi and Charles Link
@Jahnavi Post 7 by @haruspex points out an important feature in the solution of this problem. The equations of motion ## \vec{F}=m \vec{a}=m \frac{d \vec{v}}{dt}=-mg \hat{z} -.2 \vec{v} ##, (with ## m=1 ##), are such that it made for a simple linear differential equation when the ## \hat{x} ## component is considered. We glossed over this in the subsequent discussion, but it is a key feature in the solution. ## \\ ## e.g. Had the viscous force been of the form ## \vec{F}_v=-Av^2 \frac{\vec{v}}{|\vec{v}|} =-A (v_x^2+v_y^2+v_z^2) \frac{\vec{v}}{|\vec{v}|} ##, (or any other functional form as @haruspex points out), it would have resulted in a non-linear differential equation, and compounding the difficulty, the components would not have separated like they do. Any solution would have been extremely difficult, and there would have been a function of the form ## f(v_x,v_z) ## in the ## \hat{x} ## component of the vector differential equation i.e. ## \frac{d v_x}{dt}=f(v_x,v_z) ##, etc. We would have had "coupled" differential equations instead of a single simple one to solve.
Thanks !
Likes Charles Link
  • · Replies 37 ·
  • · Replies 23 ·
