_Mayday_ said:
Well that is what I thought, it probably wouldn't make a big difference if you got some well supported evidence that Psychic did not exist, as believers are not interested in changing their mind.
Let me then change my question then, how would someone go about trying to debunk something? I will ask this as a general question, though this may be a mistkae as I don't know if you can talk about it so generally.
Lets try this.
Rational thinking
Confrontation bias.
What information is presented , knowledge, facts, feelings, opinions, and thoughts to sort out and clarify. What do you know about the situation, and what do you still need to know?
Put aside the common assumption that you "already know what the problem is
People don’t like to be wrong and that anything which shows them to be wrong will be harder to accept. Also, emotional beliefs. confirmation bias aren’t all negative. It also seems likely that information which supports our beliefs is simply easier to deal with on a cognitive level — we can see and understand how it fits into the world as we understand it, while contradictory information that just doesn’t “fit” can be set aside for later.
Often when we look evidence that supports what we believe, we only ask that it leave the door open for our beliefs. But when we find evidence that contradicts what we believe, we hold it to a higher standard. We ask that it prove its findings beyond a reasonable doubt. We hold others to a higher standard than we hold ourselves.
One way that people try to confirm their beliefs is to search for evidence until they find something that supports them. They may do a very detailed, in-depth study of something, but they do not stop and evaluate what they have when they uncover evidence against their beliefs. Instead, they continue on and stop only when they've found enough evidence to support their side to relieve their conscience.
Showing evidence to be not true or to be inconclusive does not, by itself, show a conclusion to be false, but it shows it unreasonable or unwarranted to believe it on the basis of that evidence.
Other people's evidence that your conclusion is false must itself be faulty in some way if your conclusion is true; otherwise your conclusion must be false and there must be something wrong with YOUR evidence for it. Whenever there is evidence that a belief or a conclusion is true, and other evidence that it is false, there must be something wrong with at least one of those sets of evidence.
So, if someone challenges the truth of any of your reasons, you need to be able to give the evidence you believe that reason itself is true, and you then need to show why you think their challenge is itself faulty. In other words, you will be looking at the reason under attack as a conclusion itself -- a conclusion of a "prior" argument or of prior evidence
Evidence and conclusions can be disputed as being either false, unproved, improbable, unclear, or meaningless.
We shouldn't expect everyone to reevaluate their beliefs every time a new piece of evidence comes along.
However, we should draw a distinction between a belief that is well supported by evidence over time, and a belief that only has traditional or popular support.
Reinterpreting Evidence - When people are presented with ambiguous information, they often interpret it to support their established beliefs. When people are presented with unambiguous information that contradicts their beliefs, they tend to pay close attention to it, scrutinize it, and either invent a way of discounting it as unreliable, or redefine it to be less damaging than it really is.
Let's not use bad reasoning or bad science to promote good ideas
