Is there an aether to determine if an object rotates?
  • Context: Graduate
  • Thread starter Thread starter greypilgrim
    Aether
80 replies · 9K views
pervect said:
I think it would be useful to illustrate the difference between "rotating" and "orbiting", the two seem to be conflated in this thread.
I will do this by exhibiting a diagram of two orbiting bodies. Several "snapshots" are taken throughout the orbit to show the position and orientation of the body at different times. There is a "black mark" on the body to allow its orientation to be determined. While both bodies are orbiting, only one body is rotating, which clearly (to my mind at least) illustrates that the concept of "orbiting" is distinct and different from the concept of "rotating".
I haven't included examples of non-orbiting bodies in a state of rotation and non-rotation, but I hope such can be easily imagined without a diagram. Thus we see that orbiting and rotation are different concepts, a body can have any of the four possible combinations of rotation/non-rotation and orbiting / non-orbiting.
In the attached diagram, the body on the left is orbiting and rotating (with respect to the fixed stars). The body on the right is orbiting and not rotating (with respect to the fixed stars).
I hope this will be helpful and will prompt a more coherent explanation of what the question(s) are. At least some of the posters in this thread seem to be interested more in Newtonian ideas ('instantaneous action at a distance") than GR ideas ("following a geodesic").
The diagram itself is basically Newtonian as it uses the Newtonian idea of "rotation relataive to the fixed stars".
I wouldn't mind talking some about the difference between the Newtonian and GR views, but I'm not actually sensing any interest in the GR point of view ("follwing a geodesic") at this point in time. Or perhaps the interest is there, and there's a language barrier.
Let me reply with my own diagram
consider a hammer thrower who is rotating around his own axis, keeping a mass attached to a string in a circular orbit around him. In this case, the force that keeps the mass in orbit acts directly only on the part of the mass where the string is attached. The rest of the mass is just passive mass, and thus an internal stress force (i.e. an electrostatic force) must be set up in it to keep it together (this internal stress force is what we feel as 'weight' when we accelerate e.g. in a car).
Now, in contrast to this consider a 'gravitational hammer thrower', who keeps the mass in orbit by means of the gravitational force rather than a mechanical connection. In this case, the force acts directly on all atoms of the mass, so no internal stress force is set up. Ignoring tidal effects, all parts of the mass should orbit the center of force on their own account, maintaining the same orientation with regard to the local radius vector. The point is that this rotation is also inertial like the linear orbital motion, so it would not be detected by an accelerometer. It is simply a consequence of the spherical gravitational potential (in contrast, in the case of the non-rotating orbiting planet in your own diagram, the accelerometer would actually measure a rotation, as that rotation is not an inertial rotation).
So it is obvious that a purely local measurement can not only provide no answer to the question whether one is actually accelerating or not, but neither to the question whether one is actually rotating or not. The interpretation of any accelerometer measurement can only be unambiguous if the global situation is taken into account.
Which means the mass will *not* move the way you say it will, since tidal effects are what would make it "rotate" as you have drawn it. See below.
No, it isn't. Here's how you know it isn't: the way you drew the mass moving in the gravitational case is *not* the way the mass would actually move, if it were moving completely inertially (i.e., zero accelerometer reading everywhere). It would only move the way you drew it if it were tidally locked to the planet it was orbiting, as the Moon is, to a fairly good approximation, to the Earth. But orbiting satellites are *not* tidally locked; their spatial orientation is not in any way tied to the direction the Earth is in, because tidal effects are simply way too weak, over the size scale of a typical satellite.
In other words, a satellite, like, say, the International Space Station, that was really moving completely inertially around the Earth would look like the diagram on the right in pervect's post, *not* the diagram on the left. A satellite that was moving like the diagram on the left would be experiencing tidal effects and so would *not* be moving completely inertially.
No, you have it backwards. See above. The only feature of the motion that is a consequence of the "spherical gravitational potential" is the orbital motion of the center of mass of the satellite.
Look carefully at your picture of the gravitational hammer thrower - it's not correctly describing the rotational behavior of an object in gravitational orbit. The way you've drawn it, the side that is facing the top of the picture now will be facing the bottom of the picture when the object has gone 180 degrees around the orbit as the object keeps the same side facing inwards. That's an object rotating on its own axis once per orbit, and that rotation will be detectable with a local accelerometer.
If the orbiting object is not rotating about its axis, then it will be inertial and the accelerometer will just tell you that it is in free fall, not accelerating... and the accelerometer will be correct. An object in orbit is not accelerating even though it is following a curved path in three-dimensional space.
While it is true that rotation of the hammer thrower would not be detected by a linear accelerometer, it would be detected by (for example) a ring laser gyroscope. http://en.wikipedia.org/wiki/Ring_laser_gyroscope. Or an ordinary gyroscope, for that matter.
You don't need any "global" interpretation to interpret the results of a ring laser gyroscope. You do need the ring laser to enclose a finite area, which means that a ring laser gyroscope (for example) can't be pointlike - but the area enclosed can be arbitrarily small.
Similar remarks can be made about an accelerometer, actually. Any real accelerometer will need to have a finite size. If you have a mass on a spring, for instance, the mass has to be able to move to compress or stretch the string. An accelerometer can be very small, but it won't be pointlike.
"Local" does not mean that one restricts measurement to a single point. A "local" measurement of a function includes knowledge of not only the value of the function at a point, but a value of the function "in the neighborhood" of the point. This information is the same information needed to compute the function, and it's derivatives at that point.
Using this notion of local (While I"m sure it's standard, I dont' alas have a reference for it) the partial derivatives of the metric at a point give you both the readings of "linear" accelerometers and of "rotational" accelerometers. So there really isn't any problem determining when something is rotating - we have instruments that can measure it, directly, and additionally, given a metric, you can compute rotation mathematically from the Christoffel symbols - the same Christoffel symbols that you need mathematically to compute the acceleration from the metric.
Ignoring tidal effects means ignoring the gravitational force change dF from front to back of the mass compared to the force F itself. Of course, my drawing is not to a realistic scale. For e.g. any planet this should easily be satisfied, but if you want just make the mass arbitrarily small, and the assumption applies exactly.
It is not a tidal lock, on the contrary: if you ignore tidal effects (in the sense as defined above), then you can as well assume that all parts of the mass orbit independently of each other. And assuming a circular orbit, this means a part orbiting at a larger radius will stay at a larger radius, so the mass overall must rotate once over one orbit. Like I said, this rotation is fully inertial (considering the global gravitational field).
There's no need for a reference pervect. While we only need a single event to write down quantities that can be completely described by the basis vectors of a frame, the test for Fermi transport requires covariant derivatives of the frame basis vectors and as such we need neighborhoods of events to perform the Fermi transport test. The same goes for accelerometer tests since such tests require covariant derivatives of the time-like basis vector.
You seem to forget that we are not dealing with a homogeneous gravitational field here. Its direction changes through 360 deg over one orbit. So a detector co-rotating with this should be in an inertial frame and not detect anything.
Agreed; but that's not the only thing determining how the object's individual parts move. See below.
No, you can't, because the object's parts are held together by non-gravitational forces: in your model, the springs. Forcing the object to rotate as you drew it will cause the springs to stretch, because the outside pieces of the object are moving faster than the inside pieces. It doesn't matter how small you make the object: it's geometrically impossible for the object to rotate as you drew it without inducing forces in the springs.
In reality, as I noted previously, gravity will determine the motion of the object's center of mass; the motion of the other parts of the object will be determined by the springs. If the springs stay in equilibrium, which is what I understood you to be stipulating, then, as I noted, the object's motion will look like the right side of pervect's diagram.
As PeterDonis and Nugatory mentioned, you have this exactly backwards. In fact, gravity probe B was designed to detect small deviations from the inertial non-rotating satellite due to frame dragging.
The phrases "actually rotating" and "actually accelerating" are not scientifically well defined. There is coordinate acceleration and rotation or there is proper acceleration and rotation. Purely local measurements give you proper acceleration and rotation, and they are invariant. The coordinate acceleration and rotation can be made to take any value simply through a coordinate transform, so it is something that is defined rather than measured.
First of all, you were the one who said to neglect tidal effects, which means treating the field as homogeneous; so we're following directions. :wink:
Also, as I noted in my last post, the gravity of the central object only determines the motion of the object's center of mass. The motion of the other pieces of the object is determined by the requirement that the springs stay unstressed.
Look at it this way: the motion of the object's center of mass describes a circle. Since we're neglecting tidal effects, then *every* piece of the object should move in an *identical* circle, just shifted slightly in position from the circle described by the center of mass. In other words, each circle must be of the *same* radius. (Of course only one such circle, the one described by the motion of the CoM, will be exactly centered on the object; but neglecting tidal effects means neglecting the small correction due to the other circles being off-center.)
But the motion you drew does not meet this requirement: it has the outside pieces of the object describing a circle of larger radius than the circle described by the CoM, and the inside pieces describing a circle of smaller radius. That will cause the springs to show stress.
Seriously, this is such a trivial issue that you're trying to augment into something non-trivial. Nugatory gave the resolution already and it complements pervect's original drawing.
If we have an observer in free fall in some space-time geometry, an accelerometer carried by the observer will obviously measure zero acceleration: ##\xi^{\gamma}\nabla_{\gamma} \xi^{\mu} = 0## where ##\xi^{\mu}## is the observer's 4-velocity. An isotropic mass-spring system carried by the observer (of ideal size) would not be displaced from natural equilibrium during the free fall trajectory.
The observer can also carry with him an apparatus consisting of a sphere with beaded prongs attached isotropically. Clearly if the observer had non-zero spin then the beads would be thrown outwards due to centrifugal forces; if the observer had vanishing spin then the beads would remain in place. For observers in free fall this is equivalent to ##\xi^{\gamma}\nabla_{\gamma} \eta_{i}^{\mu} = 0## where ##\eta_{i}^{\mu}## are the spatial axes of the observer's frame.
These are all obviously local measurements-no global measurements are necessary.
Finally and most importantly, there are both mathematical and operational ways of differentiating spinning from orbital rotation. See pp. 221-224 of the notes I linked to yuiop earlier in this thread: http://www.socsci.uci.edu/~dmalamen/bio/GR.pdf
In a nutshell, an observer can always Fermi transport the spatial axes of his frame along his worldline. This immediately gives us the second of pervect's drawings i.e. the one in which the black marker on the particle "always faces the same direction"; we have thus determined a non-spinning frame for our observer before even talking about orbital rotation. If we now consider an observer who is possibly in a circular orbit in a stationary axisymmetric space-time, such that for simplicity the circular orbit has as its tangent field the axial killing field ##\psi^{\mu}## (not to be confused with the 4-veocity of the observer), then the observer can test to see if he is actually in a circular orbit simply by seeing if ##\psi^{\mu}## rotates relative to the spatial axes of his non-spinning frame i.e. he just has to see if ##\psi^{\mu}## changes angle continuously relative to said spatial axes along the worldline of the observer. If it does then the observer is in the circular orbit described above and if it doesn't then the observer is not in such a circular orbit. This is proven mathematically in the notes I linked above.
I was looking through a couple of my other favorite GR texts and came across additional lucid discussions of the relevant subject matter: see exercise 6.8 in MTW and section 3.4.3. of "Gravitation and Inertia"-Ciufolini and Wheeler.
If the springs stay in equilibrium, then you might as well forget about them and consider the free-fall orbit of each part of the object separately. Now, how should in this case a part circling the central mass on an inner orbit go to an outer orbit (and vice versa) after half a revolution (which is what the right hand side of pervects diagram implies)?
Only if the "free-fall orbit" you consider is consistent with all your other assumptions. See below.
Fantasist said:
Now, how should in this case a part circling the central mass on an inner orbit go to an outer orbit after half a revolution (which is what the right hand side of pervects diagram implies)?
That's not what is happening. Read my previous post again. We are ignoring tidal effects, so *all* of the parts of the object are traveling on the *same* orbit, i.e., on circles with the *same* radius. Their orbits are just centered on slightly different points. So there isn't a "inner orbit" and an "outer orbit".
Here's another way of seeing it: if we ignore tidal effects, then all of the pieces of the object see the same "acceleration due to gravity"--i.e., with respect to an observer who is static at the altitude of the object's center of mass, all the pieces of the object "fall" vertically the same distance in the same amount of time. That means the spatial curvature of all of their paths must be the same. But what you are calling the "inner orbit" and "outer orbit" have different spatial curvatures from the orbit of the object's CoM, so those are not permissible paths for the object's parts to follow. The only permissible paths are the ones I described, circles with the same radius but slightly offset centers.
My suggestion with respect to tidal effects - keep them in the analysis, but use a simple, circular shape, then demonstrate there is no net tidal torque due to tidal forces.
I hope it's already obvious that there is no net force due to tidal forces - that by definition the center of mass moves in such a manner that the tidal forces sum to zero.
I wasn't originally going to do this here, but the argument for zero tidal torque is simple enough that I'll give it a shot. Using the approach suggested by Goldstein in his textbook "Classical mechanics", IIRC called potential theory, one adds up the total potential -GmM/r of the shape to the central mass (which we will assume is a point). Goldstein is an advanced undergraduate/beginning graduate level text IIRC, but the argument is simple enough to present here.
If the summed potential changes when the orientation of the shape changes, there are tidal torques. It's apparent from the circular symmetry that this potential will not change for a disk when it rotates. Therefore there can be no net torque on a disk due to tidal forces.
If one insists on using a "hammer" shape, one will find that there are tidal torques. But there is no compelling reason to use such a complex shape. It obscures the arguments rather than illuminates them.
Using the simper circular shape, because there is no net tidal torque, the angular velocity of a rotating disk will not change. The rotation of a circular disk around its axis of symmetry is completely independent of its orbital motion.
One sees numerous examples of this in astronomy, planets all rotate at different and mostly constant rates. There are some small effects that make the rate of rotation non-constant in the real world, these are due to the lack of perfect spherical symmetry.
In astronomy, the rate of rotation of a celestial body relative to the fixed stars is called the "sidereal day". This is the absolute rate of rotation. The sidereal day can have any value.
Lets consider now a planet orbiting the sun. When the sidereal day is equal to the solar day, the planet will have one side always facing the sun, as per one of my earlier diagrams. The other example on my diagram had no rotation relative to the fixed stars. Not shown on the diagram are the infinite number of other possibilites corresponding to other rotational rates.
The question of whether or not a given extended body experiences tidal torques can be directly analyzed using the formalism of GR. Assume the extended body is small enough so that the Riemann curvature is constant across its volume and attach to the center of mass of the body a spin vector ##S^{\mu}## with ##S^{\mu}u_{\mu} = 0## where ##u^{\mu}## is the 4-velocity of the center of mass. The center of mass is then allowed to go into free fall; it can be shown that the body experiences tidal torques given by ##u^{\gamma}\nabla_{\gamma}S^{\rho} = \epsilon^{\rho \beta \alpha \mu}u_{\mu}u^{\sigma}u^{\lambda}t_{\beta\nu}R^{\nu}_{\sigma\alpha \lambda}## where ##t_{\beta\nu}## is the reduced mass quadrupole moment of the body such that ##t_{\beta\nu}u^{\nu} = 0## (see e.g. exercise 2.23 in Straumann). So whether or not ##u^{\gamma}\nabla_{\gamma}S^{\rho} = 0## depends on whether or not the body has a vanishing mass quadrupole moment (the canonical example of a body with vanishing quadrupole moment is of course a sphere).
But the direction of the vertical changes over the orbit.
Consider two astronauts on a spacewalk, with astronaut A 2 m inside astronaut B along the local radius vector of the earth. Are you suggesting that half a revolution later the situation has reversed and B is 2 m inside A?
P.S.: I am away now for week, and won't be able to reply to any posts during that time.
Merry Christmas to everbody
Yes, but what does that mean? It means that the direction of the "acceleration due to gravity" that each piece of the object is subjected to changes; but the *magnitude* of that acceleration is still the same for all pieces of the object if we ignore tidal effects. And the magnitude being the same is what makes the curvature of all the circular paths the same (the changing direction is what makes the paths circular).
If we ignore tidal effects, and if the astronauts are connected by a spring, then yes, that's what would happen.
You appear to have a mistaken notion of what "ignoring tidal effects" means, so let's put them back into see exactly what it is that we're ignoring. Consider the two astronauts, and suppose that they are *not* connected by a spring, so there is nothing constraining their relative motion. And suppose we can make measurements accurate enough to detect tidal effects over a 2 meter range. What will we observe?
Since astronaut B is in an orbit with 2 meters higher altitude, his orbital velocity is slightly slower; so the effect of tidal gravity will be to make B slowly fall *behind* A. In other words, when A has completed exactly one orbit, B will have completed slightly *less* than one orbit. So a line drawn between them will no longer be exactly radial (and its length will be a bit longer than 2 meters)--but the *direction* in which it is turned is *opposite* to the direction in which you drew the masses turning in your "gravitational hammer thrower" drawing.
Now suppose we put a spring between the two astronauts, with an equilibrium length of 2 meters. What will it do? It will pull astronaut B towards astronaut A, along a line which is slightly tilted "backwards" from radial (because B falls slightly behind A). But as this is happening, the "radial" direction is also changing, so the direction in which A and B are falling due to the Earth's gravity is changing. The net effect is that B and A remain 2 meters apart along the *original* "radial" direction--so with respect to the *new* radial direction, B is at an altitude slightly *less* than 2 meters above A, and a small distance "behind" A.
(How do we know this is the net effect? Because we are taking tidal effects into account, so B falls a slightly *smaller* distance than A; the extra motion due to the spring just makes up the difference.)
Continuing this around the orbit, after a quarter orbit, with respect to the "radial" direction there, B and A will be at the same altitude, but B will be 2 meters behind A in the orbit. After a half orbit, B will be 2 meters *lower* than A, with respect to the current "radial" direction. And so on.
All this was taking tidal effects into account: but the only way tidal effects appeared in the analysis was in the small force that the spring had to exert to keep A and B's separation constant at 2 meters. Ignoring tidal effects therefore simply means ignoring that small force. It does *not* mean changing the motion of A and B; otherwise ignoring tidal effects would not be a good approximation.
Yes, if you ignore tidal forces.
If the two astronauts are not connected together at all, or if they are connected with a tether more than 2 meters long, then no matter how small the tidal forces are they'll be more than the zero force holding the astronauts together, so you can't ignore them.
But for any moderately rigid connection between them (and a hammer is way more than just "moderately" rigid) then, yes, you will get exactly what PeterDonis says.
Yes, provided A and B experience 0 proper rotation (meaning ring interferometers detect no rotation and local gyroscopes maintain their orientation wrt A and B).
This is experimentally well proven, most dramatically in gravity probe B. There simply isn't any ambiguity on this point.
PeterDonis said:
.. You appear to have a mistaken notion of what "ignoring tidal effects" means, so let's put them back into see exactly what it is that we're ignoring. ...
All this was taking tidal effects into account: ...
I do not think this is quite right. The lack of circular symmetry of the 'two astronauts and a spring assembly' will cause tidal locking, such that astronaut A will always be *lower* than astronaut B.
The COM of the assembly will have the correct orbital velocity which means astronaut A will have a tangential velocity lower than the required orbital velocity at his altitude, meaning that A will be pulled towards the gravitational body. Conversely, B will have a tangential velocity greater than the required orbital velocity at his altitude, causing B to experience an outward force. The combined tidal effect keeps the connecting spring parallel to the instantaneous radial direction and causes a force that pulls A and B apart. For a natural orbiting body, the radius at which these force tend to tear the orbiting body apart, is known as the Roche limit.
To minimise this effect, the orbiting body should be small and ideally have spherical symmetry.
Eventually, yes, but it will take many orbits for the lock to develop, and this branch of the thread is discussing what happens halfway around the first orbit after the initial conditions have been set up. It's reasonable to consider tidal forces but not the cumulative effect of the locking torque under those circumstances.
This is a different initial condition from the one I was considering. I was considering an initial condition where both objects, A and B, have the correct (different) tangential velocities for their altitudes, but then we put a spring between them. Your initial condition is that A and B both have identical tangential velocities, *not* correct for their altitudes. Changing the initial condition can change the result.
Correct.
I should also add that, as I understand it, tidal locking is a dissipative process--for example, the Moon became tidally locked to the Earth because when it wasn't locked, there was friction within its interior as the tidal bulge caused by the Earth moved. In order to include this effect in our scenario, we would have to add dissipation to the spring; with an idealized perfectly elastic spring, there wouldn't be any tidal locking.
Yes, an object in the outer orbit will fall behind, and an object in a lower orbit will advance in its orbit relatively to the center of mass. That's why you have to accelerate the former and decelerate the latter to preserve the spatial configuration, i.e. you have to rotate the whole system forward (as indicated in my diagram).
Of course, for a rigid body, its constituents would be kept together anyway due to the electrostatic force, but the tendency for the parts to drift apart would create a stress force in the body. You can eliminate this stress force by rotating the body forward synchronously in its orbit. So the bound rotation of an object should correspond to an inertial state (or something close to it anyway, as I don't think the stress force can be completely neutralized through simple rotations or translations other than in first order of r/R, as the orbital velocity is ~1/sqrt(R+r)).
I realized now that it was wrong to assume the absence of tidal effects here, as the whole issue in fact is about tidal effects.
Even for perfectly spherical bodies, the inclusion of tidal effects (i.e. the variation of the gravitational force inside the body) is actually already implied by the 'Shell Theorem' (i.e. Gauss's law), so it would be a contradiction in terms to neglect them.
*If* they are both moving freely. But if they're connected by springs, they're not moving freely.
Yes, that's what the spring does--but that just maintains the system's orientation in the *original* radial direction. If the spring were not there, a line connecting A and B would rotate *backwards* relative to the original radial direction. So this...
...is not correct. The spring just counteracts the *backward* rotation that would be present if A and B were moving freely. It does not add any forward rotation.
Which the parts of the body would move, if possible, to eliminate, just as A and B move to eliminate the stress in the spring. The equilibrium configuration of the body is still unstressed; you can't keep it stressed in equilibrium if the body as a whole is in free fall (in the absence of tidal effects--see below).
No, you eliminate the stress force by *not* rotating the body at all, instead of letting it rotate backwards due to tidal effects. See above.
Yes, in the absence of tidal effects. See below.
In the absence of tidal effects, there is zero stress force if the body as a whole is in free fall. If tidal effects are included, then yes, there will be small internal stresses present due to tidal effects. However, those by themselves won't cause the object to rotate; you need dissipation as well. See further comments below.
No, there are two separate issues, as the discussion between yuiop, Nugatory, and myself in this thread shows. Tidal effects will *eventually* cause the orbiting body to rotate once per revolution, as per your "hammer thrower" drawing; but this happens on a much longer timescale than a single orbit. And the mechanism of tidal locking involves dissipation, so it requires damping in the springs in your simplified model; idealized perfectly elastic springs would *not* cause tidal locking, and so would *not* cause any forward rotation.
Huh? The "Shell Theorem" talks about variation due to the object's own self-gravity; it has nothing to do with variation of the gravity seen by a small object orbiting a much larger one.
Sorry, but I disagree. If you pull on an object, you can release the associated stress by accelerating the object forward (in the direction of the pull), not be leaving it stationary or even pulling it backward. So if the center of mass pulls on the orbitally lagging part of the object, the stress is released (or minimized) by moving the latter in the direction of the pull (i.e. by rotating it forward).
The cause of the tidal locking wasn't the issue here. Only whether the tidally locked (i.e. bound) rotation is the inertial situation or not. Intuitively, one should expect that all systems should eventually settle into an inertial state, and most moons in the solar systems for instance seem to confirm this as they have a bound rotation.
While that certainly is a valid alternative scenario, it is a different scenario from what has been proposed and discussed up until now. In such a scenario the astronauts will experience locally measurable rotation. Ring interferometers will give non-zero results and local gyroscopes will precess wrt the astronauts.
