Is there an analytic solution to this system of equations?
The discussion revolves around the possibility of finding an analytic solution to a specific system of equations involving the variables ##a## and ##m##. Participants explore both the theoretical aspects of the problem and numerical methods for approximating solutions.
  • One participant presents a system of equations and questions the existence of an analytic solution, noting that numerical approximations yield specific values for ##a## and ##m##.
  • Another participant suggests substituting variables to simplify the equations, proposing a rearrangement that may facilitate solving for ##a##.
  • A different participant argues against the existence of an analytical solution and provides a detailed numerical approach, introducing new variables and transformations to reformulate the problem.
  • Further elaboration on the numerical method includes the introduction of a function ##F(\zeta)## and discusses potential roots and conditions under which the function could equal zero.
  • A participant expresses gratitude for the detailed numerical explanation and seeks clarification on the terminology used in the approach, indicating a desire to learn more about the concepts involved.
Participants generally agree that an analytical solution is unlikely, but multiple competing views on the numerical methods and approaches remain. The discussion does not reach a consensus on the best method or the implications of the findings.
Participants note the complexity of the equations and the challenges in establishing a domain for the variables involved. There are unresolved mathematical steps and assumptions that could affect the proposed numerical solutions.
END
I have the following system of equations with variables ##a,m##, and I'm wondering—can this system be solved symbolically/analytically?
\begin{align}
m &= 100 + \frac{ \left( 200 \frac{\ln{\frac{1}{2}}}{26.8} \right) }{\left(\dfrac{\ln{\frac{1}{2}}}{26.8} + a \right)}
50 &= me^{-a\left( 19.9 \right)}- \frac{ \left( 200 \frac{\ln{\frac{1}{2}}}{26.8} \right) \exp{ \left(\dfrac{\ln{\frac{1}{2}}}{26.8} \cdot 19.9 \right) }}{\left(\dfrac{\ln{\frac{1}{2}}}{26.8} + a \right)}
\end{align}
(What are some ways to recognize that a problem does or does not have an analytic solution?)
For this specific example, I understand the answers can be numerically approximated to
\begin{align}
a &\approx 0.092409
m &\approx 22.2674
\end{align}
Via such numerical methods as a graph:
or other computational device such as WolframAlpha [(link to this problem). For this specific problem, WolframAlpha only provided a numerical approximation.
Note: The variables in the WolframAlpha link are ## a, n ## respectively
If you replace the factor ln(0.5)/26.8 with K and use x and y for a and m you get for the first equation:
y = 100 + 200K/(x+K)
and for the second you get:
50/e^19.9 = y - 200Ke^K/(x+K)
which rearranges to:
y = 50/e^19.9 + 200e^K/(x+K)
From here you can set the equations equal to each other and solve for x noting that x=/= -K
I don't see an analytical solution. For a numerical solution, consider the following:
With
\begin{align*}
m &= 100 + 200 \cdot \frac{\beta}{\beta+a} \\
50 &= m \cdot e^{-19.9a} - 200 \cdot \frac{\beta}{\beta+a} \cdot e^{19.9 \cdot \beta}
\end{align*}
Where [itex]\beta = \ln(1/2) / 26.8 \approx -0.02586[/itex].
Multiply the second equation by [itex]\exp{(19.9 \cdot a)}[/itex]
\begin{equation*}
50 \cdot e^{19.9 \cdot a} = m - 200 \cdot \frac{\beta}{\beta + a} \cdot e^{19.9 \cdot \beta} \cdot e^{19.9 \cdot a}
\end{equation*}
Let [itex]w= \beta + a[/itex] and substitute first equation into second to yield
\begin{equation*}
c \cdot e^{19.9 \cdot w} = \left[100 + 200 \cdot \frac{\beta}{w}\right] - 200 \cdot \frac{\beta}{w} \cdot e^{19.9 \cdot w}
\end{equation*}
where [itex]c = 50 \cdot e^{-19.9 \cdot \beta} \approx 83.6558[/itex].
This is a non-linear scalar equation in one parameter [itex]w[/itex]. A numerical solution will be necessary. Before we go down that path, re-scale and introduce a non-parametric variable for [itex]w[/itex]. Let [itex]\alpha = a / \beta[/itex], [itex]\zeta = w / \beta = 1 + \alpha[/itex] and re-formulate into [itex]F(\zeta) = 0[/itex].
\begin{equation*}
F(\zeta) = 0 = 100 \cdot \left[ \left(\gamma + \frac{2}{\zeta}\right) \cdot e^{\lambda \cdot \zeta} - \left(1 + \frac{2}{\zeta}\right) \right]
\end{equation*}
where [itex]\gamma = c / 100[/itex] and [itex]\lambda = 19.9 \cdot \beta \approx -.51469[/itex].
This could be solved numerically, but we don't know the magnitude or an applicable domain bracket that contains [itex]a[/itex] (ie, [itex]\zeta[/itex]). If we look at the above equation for [itex]F[/itex], we see it is equivalent to
\begin{equation*}
F(\zeta) = 100 \cdot \left[
\left(1 + \frac{2}{\zeta}\right) \cdot \left(e^{\lambda \cdot \zeta} -1\right) - \mu \cdot e^{\lambda \cdot \zeta}\right]
\end{equation*}
where [itex]\mu = 1 - \gamma \approx .167[/itex].
If we ignored the last term, we would underestimate [itex]F[/itex] (since [itex]\mu > 0[/itex] and the exponential is positive). But if we did, we would see that two conditions could result in [itex]F= 0[/itex]:
First: [itex]\exp{(\lambda \cdot \zeta)} - 1 = 0[/itex]. This would imply [itex]\zeta = 0[/itex] or [itex]a = -\beta \approx 0.02586[/itex]. The scaled error term in [itex]F[/itex], which is the last term in the expression above, is [itex]E = -\mu \cdot e^{\lambda \cdot \zeta} = -\mu = -0.167[/itex]. However, this is probably not a good idea since we have the [itex]1/\zeta[/itex] term which contradicts this solution.
Second: [itex]1 + 2 / \zeta = 0[/itex]. This would imply [itex]\zeta = -2[/itex] or [itex]a = -3 \cdot \beta \approx 0.07759[/itex]. The scaled error term in [itex]F[/itex] is now [itex]E = -\mu \cdot e^{-2 \cdot \lambda} \approx -0.456[/itex]. That's probably a safer bet. However, since we underestimate [itex]F[/itex], we should probably bump up this value somewhat (ie, decrease [itex]\zeta[/itex] somewhat away from [itex]-2[/itex]).
Selecting [itex]\zeta = -3[/itex] yields a scaled value [itex](1/100) \cdot F(-3) \approx 0.4301[/itex]. We have now bracketed the root. A suggested initial value for an iteration routine would be [itex]\zeta^{(0)} \approx -2.5[/itex] (ie, [itex]a^{(0)} = 0.09052[/itex]).
Thank you for the in-depth explanation to a numerical approach, TheoMcCloskey! The technique you outlined is just beyond my current mathematical level of understanding, but it's educating to see a technique like that in action, and it's definitely brought up some points to research.
Does your approach have a specific name? I can't wait to study these concepts in the future.
  • · Replies 16 ·
