The discussion revolves around the presence of noise detected in a neutral wire with a sense resistor connected in series. Participants explore the characteristics of this noise, its potential sources, and measurement techniques, focusing on high-frequency noise observed in a 240V single-phase system.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant reports detecting noise of 500mV - 1V across the sense resistor at high frequencies (60kHz - 100kHz) even when the power plug is inserted but not switched on.
- Another participant requests a schematic to better understand the setup.
- Several participants suggest measuring the voltage on each side of the sense resistor with respect to ground to identify the noise source.
- Concerns are raised about potential voltage buildup between conduit ground and the neutral wire, particularly in non-North American wiring practices.
- Some participants propose that the noise may not be across the sense resistor but rather due to each wire acting as an antenna.
- There is a suggestion to use an isolation transformer to eliminate common mode noise and improve measurement accuracy.
- Participants discuss the possibility of common mode noise affecting measurements and the need for better common mode rejection in the measurement circuit.
- One participant questions the op-amp input stage design, suggesting it may not provide adequate DC feedback.
- Another participant notes that the same noise is observed at the transformer secondary, indicating it may not be common mode noise.
- There are suggestions to redesign the isolation transformer for better high-frequency isolation and to improve the balance of the measurement circuit.
- One participant asks if a low pass filter could help mitigate the noise issue.
- Concerns are raised about the physical layout of the setup, with suggestions to disconnect components that could be oscillating.
Participants express various viewpoints regarding the source and nature of the noise, with no consensus reached on the underlying cause or solution. Multiple competing theories and suggestions are presented, indicating an unresolved discussion.
Participants acknowledge limitations in their understanding of wiring practices outside their regions, and there are references to potential issues with grounding and circuit layout that may contribute to the observed noise.
