Is this a valid parametrisation of a curve?
  • Thread starter Thread starter rickonstark999
    Curve
The discussion centers on the parametrization of the curve defined by y² = 16x. The user proposes letting x = t², leading to y² = 16t², and questions whether to include a "plus or minus" in front of 4t for a valid parametrization. It is clarified that since t can take both positive and negative values, the correct parametrization is x = t² and y = 4t without needing the "plus or minus." The conclusion confirms that this parametrization accurately represents the curve for all real values of t.
rickonstark999
Member warned that the homework template is required
Hi, so I am learning how to parametrise curves.
For the curve y^2=16x, I have said let x=t^2. Then, we can say y^2=16t^2, so that we can take the root of this and get y=4t. What I wanted to ask was do we have to say "plus or minus" in front of the 4t, or do we just leave it as positive to get a valid parametrisation?
Thanks.
Thanks.
The question to ask is what values can ##t## take?
Thanks.
Is ##y## allowed to be ##<0## along the curve? Is ##t < 0## allowed?
I suppose so? The question doesn't specify so I am not sure.
How would you draw a graph of the relation ##x = \frac{1}{16} y^2##?
You would have a sideways parabola where y can be any real number, but x cannot be below 0 because you are squaring.
OK, so now what does that tell you about ##t## in your parametrization?
From my parametrisations, t can be both positive and negative. Would you say that is correct?
No, that isn't right. If ##y^2 = 16t^2##, then ##y = \pm 4t##.
Thank you. That is what I was asking in the sentence after that.
But @rickonstark999, you do understand that your first post above is correct and your parameterization ##x=t^2,~y=4t## with ##t## both positive and negative, ie ##-\infty < t < \infty## is a correct parameterization of your curve, right? You don't need any ##\pm## sign.
Likes PeroK
