Is this considered as a function?
  • Thread starter Thread starter Michael_Light
    Function
The discussion centers on whether a given equation can be classified as a function. It is established that for an equation to be a function, each input must correspond to a unique output, which can be validated through the vertical line test. While the equation "y = √(3 - x)" is initially presented, it is clarified that specifying a domain makes it a function. The conversation also touches on the distinction between general functions and one-to-one functions, emphasizing that all functions must pass the vertical line test, while injective functions must also pass the horizontal line test. Ultimately, the importance of defining functions accurately is highlighted, as non-function mappings can lead to confusion.
Michael_Light
such that x is real number and x =< 3
Mathematics news on Phys.org
Yes.
To each valid input of x, there is only one associated y-value.
I.e, "y" is a function of x.
Actually, it is an equation, not a function. This equation can be used to define a function by someone who knows what he is doing.
Michael_Light said:
View attachment 35474 such that x is real number and x =< 3
For future reference, one easy test to check if something is a function is to do a vertical line test. Basically what you do is if you find a point where a vertical line crosses two or more points it is not an explicit function. To make it an explicit function you need to restrict the domain.
So as an example x^2 + y^2 = 1 is the unit circle, but is not a function unless you restrict the domain. You can draw a vertical line it will always intersect two points unless your y value is zero.
For clarification, we're talking about "one to one" functions.
No, "y= \sqrt{3- x}" is an equation but the additional "such that x is a real number and x\le 3" states a domain and makes this a function.
Where did you get that idea? The original function happens to be one to one but that was irrelevant to the question and to the responses.
Right, true. Yes, ok. Fine, but functions don't by definition need to be one-to-one. That's just an injective ("one-to-one") function. Restricting the domain to pass the vertical line test doesn't need to happen to define it as a function...just a one-to-one function.
I thought if followed and might be useful for the poster to know about the broader categories of functions than just the injective type. A function is many things. An injective function passes the vertical line test, if you like. No disrespect intended.
No, every function must pass the vertical line test. It is the horizontal line test that is used to determine the injective functions.
Or am I messing up horizontal and vertical again?
I mean function like "mapping elements from a set A to a set B." (Rudin, 3rd ed.) You know? No bijectivity required.
no, a function must pass the vertical line test. A one-one function passes a similar "horizontal line test". This is by definition
If the vertical line test fails, you can call it some sort of " general mapping" from a set A to a set B, but it may not be well-defined.
For micromass, | <-- vertical __ <-- horizontal, think of the horizon :P
Yes, the base definition for a function is that for every element of x, there is a unique y.
It's the "general math" forum! The answer should be general!
Well, a function is *not* some sort of "general" mapping, and that is what the poster specifically asked for. Furthermore, a non-function mapping may not be well-defined, and thus be non sensical: suppose f ( x ) = y and f ( x ) = t, where y != t. Then f(x) = y != t??
A function is the most "general mapping" that is worth talking about, a non-function mapping can just be nonsense.
Oops! You win. "Relation." Apparently I forgot "relation."
