Is this considered factored form
  • Thread starter Thread starter AllanW
    Form
The discussion revolves around the expression 6(2x+5)^2(6x-1)^5+(2x+5)^3(30)(6x-1)^4, which the original poster derived from differentiating a product of binomials. The main question is whether this expression can be considered in factored form due to the presence of a '+' sign.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the possibility of factoring the expression further and question whether it can be expressed solely as a product. There are discussions about identifying common factors and the implications of the '+' sign in the context of factoring.
Some participants have provided guidance on factoring out common terms and have suggested starting with the identification of common factors in the expression. There is an ongoing exploration of how to combine terms and whether coefficients should be included in the final factored form.
There are references to specific algebraic manipulations and the need to account for coefficients during the factoring process. The discussion also touches on the relevance of proper terminology in differentiation and the categorization of the problem within the forum's sections.
AllanW
this is what i got from deriving (2x+5)^3(6x-1)^5 and now i have to express my answer in factored form, does this classify as factored from even though it has a '+' in it?
You can take it one step further so that you only have products.
this is what i got from deriving differentiating (2x+5)^3(6x-1)^5 and now i have to express my answer in factored form, does this classify as factored from even though it has a '+' in it?
By the way, the verb form for finding the derivative is "to differentiate".
Differentiation
The process of finding a derivative.​
That is not factored form.
There are common factors of: 6, (2x + 5), and (6x − 1) , to various powers.
okay, is there an easier way of combining the exponential binomials or do i have to expand all of them out completely and try to find a way to factor them back down?
Expanding them would be counter productive.
Facotr out all of the common factors. Then see what's left and proceed from that point.
@AllanW, Problems involving differentiation should go in the Calculus & Beyond section. I have moved it for you.
i know, but my question was about the factoring part of the question which is why i had it under pre-calc
As SammyS pointed out, you have something of the form ##A^2B^5 + A^3B^4.##
Start by taking it down to ##A^2B^4(B+A). ##
Since B and A are both binomial terms, their sum will also be a binomial.
okay, so you're saying I should get:
(2x+5)^2(6x-1)^4((6x-1)+(2x+5))→(2x+5)^2(6x-1)^4(8x+4)
what do I do with my coefficients?
That's right. Now do the same thing and keep your coefficients in there. SammyS pointed out that 6 was a common factor between them, so you will have to account for the leftover 5 by keeping with its binomial term.
Don't ignore them!
so i should get 5(2x+5)^2(6x-1)^4(8x+4)?
5 is not a common factor. 6 is a common factor
You have made some algebra errors.
No.
You started with
##6A^2B^5 + 30A^3B^4.##
Which is ##6A^2B^4(B+5A). ##
okay, so it is apparent i have no idea how A^2B^5+A^3B^4=A^2B^4(B+A) perhaps we start there?
In the form:
##A^2 B^5 + A^3 B^4,##
first look at term A.
There is a power of 2 and a power of 3. The smaller of these is 2, so ##A^2## is a common factor. Factor it out and you have:
##A^2( B^5 + A B^4).##
Next look at term B. Same rules apply, and you have a common factor in the sum of ##B^4.## Factor that out and you have:
##A^2B^4( B + A ).##
If you had coefficients, like 6 and 30, you would do the same thing...find the common factor, factor it out, and leave behind any part that was not factored.
If this is not making sense, please review the distributive property of multiplication...which tells you that:
a(b+c) = ab+ac.
This is what allows you to factor in this way...if you are given something like ab+ac, you can put it in factored form of a(b+c).
okay that makes sense, so would 48(2x+5)^2(6x-1)^4(2x+3) be my final answer?
There is an "[itex]A^2[/itex]" in the first term and "[itex]A^3= A^2(A)[/itex]" in the second term so you can factor out [itex]A^2[/itex] from both, leaving "A" in the second: [itex]A^2B^5+ A^3B^4= A^2(B^5+ AB^4).<br /> <br /> There is a "[itex]B^4[/itex]" in the second term and "[itex]B^5= B^4(B)[/itex]" in the first term so you can factor out [itex]B^4[/itex] from both, leaving "B" in the first: [itex]A^2(B^5+ AB^4)= A^3B^4(B+ A)[/itex].[/itex]
That looks right to me.
Great, thanks!
This is just a special case. Convince yourself that whenever you differentiate unvm, you are always going to get something factorable. You could work out how you could differentiate in such a manner it doesn't split up and need to be recombined.
  • · Replies 18 ·
  • · Replies 18 ·
