Can internal pressure push a button on an airtight chamber?
5 replies · 3K views
physsure
Hi!
Given that the chamber is airtight and no air leakage occurs, is the design in the picture below possible? Can the pressure inside the chamber cause the button (black part at the top) to be "pushed"?
https://imgur.com/a/wOSD30D
Obviously the temperatures are over-exaggerated, but the principle is the same at very high temperatures.
It's not clear what's going on here. Are you attempting to represent the effects of Convection, caused by the red (=hot?) at the bottom?
If so, the convection currents will indeed exert a force on a horizontal (?) disc at the top. It does require a suspension of disbelief, though because the push rod will also be subject so any difference in pressure between inside and outside. A small cross sectional area of hole but, nonetheless there will be an upwards force which may or may not balance the weight force of all the button and disc. A more reasonable scenario would be to use some balanced lever mechanism to transfer the force to the outside.
physsure said:
Hi!
No, bad design. Thin neck of button as depicted reduce actuation force as square of neck diameter. It can work, but margin for setting pressure of seal nearly non-existent.
If this is a thought experiment then it should, at least. take account of such things and the design should eliminate their effect; it is perfectly possible to do so.
How much force is it possible to assert through convection? It must be minimal but is it possible to calculate given a scenario?
We are operating in an information vacuum here. You need to describe what it's all about, what is supposed to happen and what's the idea based on? Remember- PF knows nothing about the workings of your mind. We can only comment on what we read and see.
