Is this sufficiently proven? ( A set being a convex set)
10 replies · 2K views
Dazed&Confused
Hi, just a few details prior: I'm trying to study techniques for maths proofs in general after having completed A level maths as I feel it will be of benefit later when actually doing more advanced maths/physics. With this question what is important is the proof is correct which means I don't actually know what a convex set is or what it is useful for...
P.S sorry if this is the wrong sub forum.
Prove that if a and b are real numbers, then the set C= { real numbers x: ax ≤ b} is a convex set.
tx + (1-t) y ( for convex sets)
ax ≤ b
To show that C = x ≤ [itex]\frac{b}{a}[/itex] is a convex set let x and x' be members of C.
The inequality must hold:
tx + (1-t)x' ≤ [itex]\frac{b}{a}[/itex]
Case 1)
Assume x ≤ x' ≤ [itex]\frac{b}{a}[/itex]
Then
t(x-x') ≤ 0
and hence t(x-x') +x' ≤ [itex]\frac{b}{a}[/itex]
Case 2)
assume x' ≤ x ≤ [itex]\frac{b}{a}[/itex]
Then
(1-t)x' ≤ [itex]\frac{b}{a}[/itex] -tx ≤ (1-t)[itex]\frac{b}{a}[/itex]
(1-t)x' ≤ (1-t)[itex]\frac{b}{a}[/itex]
And hence the inequality holds for both cases Q.E.D
ax ≤ b
Case 1)
Then
t(x-x') ≤ 0
Case 2)
Then
How do you get that middle term from (1-t)x?
Why not just calculate ##a(tx + (1-t)x')## directly and show it is ##\le b##? No separate cases needed.
I thought about that but not sure how to go about it. I mean wouldn't you essentially be doing the same thing?
and sorry I'm don't know what term you are referring to. Do you mean the x' term instead of x?
Thanks for reply btw.
ax ≤ b
Case 1)
Then
t(x-x') ≤ 0
Case 2)
Then
Note: you need to be careful! The inequalities ax ≤ b and x ≤ b/a are equivalent only if a > 0. If a < 0 you need to reverse one of the inequality signs, and if a = 0, one of them does not make sense.
whoops :/ .. well say I kept the inequality in the question and changed all the other inequalities accordingly e.g.
at(x-x') + ax' ≤ b
etc... does that then make the proof valid?
Then
(1-t)x' ≤ [itex]\color{red}{\frac{b}{a} -tx}[/itex] ≤ (1-t)[itex]\frac{b}{a}[/itex]
I'm referring to the expression in red.
No. It's really simple. Expand it and use what you know about ax and ax'.
rearraged tx + (1-t)x' ≤ b/a
although now thinking about it.. looks like circular reasoning to me
so tax + (1-t)ax' ≤ tb + (1-t)b = b ?
yh pretty simple... makes me feel like a simpleton.. thank you anyway
