Is Voltage a measurement of pressure?
The discussion revolves around the relationship between voltage and pressure, particularly whether voltage can be considered a measurement of pressure in electrical circuits. Participants explore the conceptual and dimensional differences between voltage and pressure, drawing analogies to fluid systems while highlighting the limitations of such comparisons.
  • Some participants assert that voltage and pressure are fundamentally different concepts, with voltage representing the potential energy difference between two points in a circuit.
  • Others argue that while voltage and pressure are dimensionally different, they can be conceptually similar in certain contexts, particularly in introductory explanations.
  • A participant notes that measuring voltage involves understanding the chemical potential of electrons, which complicates the analogy to pressure.
  • Some contributions emphasize that using fluid analogies can lead to misunderstandings in electrical theory, suggesting that electricity should be treated as a distinct field of study.
  • There are discussions about the term "electro-motive pressure" as a potentially more accurate descriptor for voltage, linking it to fluid flow models.
  • Participants highlight that both electrical and fluid systems have their complexities, and oversimplifying one to explain the other can be misleading.
Participants do not reach a consensus on whether voltage can be equated to pressure. There are multiple competing views regarding the relationship between the two concepts, with some advocating for their distinction and others exploring their similarities.
Limitations in the discussion include the reliance on analogies that may not fully capture the complexities of electrical systems, as well as the varying interpretations of terms like "pressure" and "force" in different contexts.
  • #31
robphy said:
Of course, this isn't to say that these are completely analogous...
but from this limited energy [work-done] point of view, they [in particular, voltage and pressure] are analogous.
frankin garcia said:
That is exactly the answer i was looking for, thanks, now i just got to do more research to validate all this and more. 👍
But do note that as robphy says, they are not completely analogous. As with all analogies, there’s only so far that this one can go. You can use it as long as it helps you form an intuitive mental picture of what’s going on, but any time that it’s not helping you understand you should give it up.
  • #32
I think there's an enormous problem with initial teaching using the water model. That is the pipes and the wires can erroneously be taken as equivalent components but, at the same time, the pressure drop along pipes of different bores is taken as a dominant image. That is a seriously confusing issue for students who will never have experience of water flow. I can't think of a single experimental experience that kids get of water flow (after nursery school, that is).
There are two strands to the contributions to this thread - from informed people who can find positive correlation at a technical level and from people who try to envisage teaching very uninformed students. The 'intellectual' links across Science are valid but the 'intuitive' links are much more tenuous. For teaching, one has to think concrete.
  • #33
On that note, how would you explain when i change the amount of voltage in my welder, let's say for sake of scenario, the voltage goes up and the plasma flame, i'll notice, has more force, power, Newtons per area it seems. Which from what i know, that action is also called pressure. If i bring the volts down, clearly the opposite occurs with the flame completely ran on electricity and argon/helium. Maybe I am not interpreting force, Newtons and power correctly.
  • #34
More current will produce more heat which causes more volume of evolved gases. The actual pressure increase will be infinitesimal as the gases expand in all directions against only atmospheric pressure to restrict it. That's what you notice; more flame.
  • · Replies 25 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 58 ·
  • · Replies 23 ·
  • · Replies 105 ·
14K
  • · Replies 22 ·
