Isolating the Y variable in a Trigonometric Equation
The discussion centers on isolating the variable y in the equation 4y = cos(4πx + 3/2). The initial attempt to divide both sides by 4 was deemed incorrect because it misapplied the rules of algebra regarding functions. It was clarified that when dealing with functions like cosine, one cannot distribute a factor into the function itself. Instead, the correct approach is to treat the cosine function as a whole and isolate y by expressing it as y = (1/4)C, where C represents the cosine function. This understanding helps avoid confusion when working with trigonometric equations.
opus
##4y=cos\left(4πx+\frac{3}{2}\right)##
In dividing both sides by 4, I got:
##y=\frac{1}{4}cos\left(πx+\frac{3}{8}\right)## But I am told this is incorrect.
Not sure if dividing everything by 4 here is an allowable technique, or if I did it wrong, but I'm not sure where else to go other than isolating the y like this.
Actually I think I got it. I tried dividing the LHS by 4 and ONLY the coefficient of cos on the RHS and that seemed to work. My algebra seems to go out the window when I see trig words, so why wouldn't I divide all factors on the RHS by 4?
No, it is wrong. When dividing a product, you divide only one factor.
Think: what is y if 4y = 12? and what is y if 4y=3x4? Do you really think the two y values are different?
Likes opus
Makes complete sense now. Thank you!
True, but ##\cos(4\pi x + \frac 3 2)## isn't a product.
Closer to the point, if ##4y = \sqrt{36}##, it would be incorrect to write ##y = \frac 1 4 \sqrt 9## (which happens to be ##\frac 3 4##). The corrected equation is ##y = \frac 1 4 \sqrt{36} = \frac 6 4 = \frac 3 2##.
Of course, with this equation, it would have been simpler to write it as 4y = 6, from which we get y = 3/2.
Likes opus
Thank you Mark. So what would we call it if not a product? Just a typical function such as f(x) where we wouldn't be dividing the input of the function?
If the trig function is throwing you off, just call it something else (temporarily). If you let ##C = \cos(4 \pi x + \frac 3 2)##, your original equation is ##4y = C,## and the solution is ##y = \frac1 4 C.## Now put back the value of ##C## in terms of ##x##. When you do that it becomes absolutely clear that you do not pull the ##\frac{1}{4}## inside the ##\cos( \cdot) ## function.
Likes opus
Ray Vickson said:
If the trig function is throwing you off, just call it something else (temporarily). If you let ##C = \cos(4 \pi x + \frac 3 2)##, your original equation is ##4y = C,## and the solution is ##y = \frac1 4 C.##. Now put back the value of ##C## in terms of ##x##. When you do that it becomes absolutely clear that you do not pull the ##\frac{1}{4}## inside the ##\cos( \cdot) ## function.
Im going to try that! Thats a great idea, thank you.
Just call it a function. The expression "f(x)" does not mean "f times x", so it's definitely not a product. It's almost never the case that ##\frac 1 b f(x)## is equal to ##f(\frac 1 b x)##, so you generally can't "distribute" the factor ##\frac 1 b## to into the function.
Here are some example of what I mean:
##\frac 1 2 \sin(x) \ne \sin(\frac x 2)##
##\frac 1 3 \sqrt{x} \ne \sqrt{\frac x 3}##
##2e^x \ne e^{2x}##
and so on. In the above, ##\ne## should be interpreted as "not identically equal to." For some of my examples, there might be values of x that make the expressions on each side equal, but for most values of x, the paired expressions aren't equal.
Likes opus
Thanks Mark!
