Jacobian of the transformation
2 replies · 2K views
Niles
Hi
I wish to perform an integral of the form
[tex] \int_0^a {\int_0^b {f\left( {x - y} \right)dxdy} } [/tex]
What I do first is to define s := x-y, and ds = dx. Then we get
[tex] \int_0^a {\int_{-y}^{b-y} {f\left( {s} \right)dsdy} } [/tex]
Then I can define t := x+y, so dt = dy. Then I get
[tex] \int_{x}^{x+a} {\int_{-y}^{b-y} {f\left( {s} \right)dsdt} } [/tex]
I also have to multiply by 2, since it is the Jacobian of the transformation. But look at the limits: It doesn't seem to make things easier. Where am I going wrong?
Well, what, exactly do you want to do with that? You obviously can't "do" the integral without knowing what f is. However, your limits of integration in the final integral makes no sense. From the first form, since the limits of integration are constants, the integral does not depend on x or y but your last form for the integral clearly does.
The region of integration in the x,y plane is a rectangle with sides parallel to the x and y axes. In the u,v plane it is still a rectangle but with sides at 45 degrees to the u and v axes. Depending on what a and b are, you would probably have to divide the area into two separate integrations. In any case, I don't see that change of variable helping.
The reason why I am asking is because in my book they write the following
[tex] I = \int_0^a {dt_1 \int_0^a {dt_2 \,F(x,t_1 - t_2 )} } F(y,t_1 - t_2 ) = a\int_0^a {dt\,\,F(x,t)F(y, - t)} [/tex]
I cannot quite see how the second equality-sign comes about. I thought it came from substitution, as above.
