Jacobian transformation problem
8 replies · 2K views
oferon123
Find surface inside four boundary curves:
[itex]xy = 4 , xy=8 , y=5x , y=15x[/itex]
using the transformation: [itex]u=xy , v=\frac{y}{x}[/itex]
I'm getting the new bounds to be:
[itex]4 < u < 8[/itex] , [itex]-15 < v < -5[/itex] OR [itex]5 < v < 15[/itex]
Jacobian is [itex]\frac{1}{2v}[/itex]
After integration i get [itex]0.5*ln(v)[/itex] which I can't put -15 nor -5 in it..
On the solution they gave us, they completely ignore the surface at x,y < 0 and go only for 5 < v < 15 , which I assume is only relevant for the surface at x,y > 0...
As if they calculated only the half of the area.
I understand all I need to do is double this area, but where am I going wrong?
I attach this sketch I've drawn trying to understand what's going on:
They make use of the oddness of all four functions provided to calculate only one of those areas and then double the result.
Yes, I do understand that.
However I don't understand how your'e supposed to see that unless you draw everything.
More important - even if I do draw it, I don't understand why I get stuck with the method and can't integrate over -15 < v < -5
I obviously do something wrong if I can't, the question is what
Maybe it's got something to do with the transformation not being injective?
Honestly, it is not too hard to see that those functions are odd - I spotted it before even looking at your sketch of the functions. A function is odd if it satisfies [itex]f(-x) = -f(x)[/itex]. You can check that without drawing anything.
On your mistake, you seem to be missing a very simple fact: [itex]\displaystyle \int \frac{dx}{x} \neq \log(x) + C[/itex], but instead, [itex]\displaystyle \int \frac{dx}{x} = \log|x| + C[/itex].
Oh your'e right, thanks a lot!
But now I have this new question I asked..
If this transformation is not injective, how come it works?
for example: for x=-1, y=-1 and x=1 y=1 we get the same v=1
Thanks again!
I tried to play with [itex]u=xy , v=\frac{y}{x}[/itex] a little and that's what i got.
If I'm wrong then where is the negative region in xy is transformed to in uv region?
The way I drew it - one goes to the upper square at uv, and the other goes to lower square.. Is it not?
What haruspex is saying is that you can't get negative values for u and v in the regions you want to find the area for. Negative values would show up in the second and the fourth quadrants, but not in the first and the third; and you don't have the curves [itex]xy = c[/itex] for c constant in those quadrants. It will still give the correct answer though, because it just happens to integrate into the same thing; albeit out of luck.
