How Do You Apply Jacobian Transformation to Evaluate a Double Integral?
The discussion revolves around applying a Jacobian transformation to evaluate a double integral involving the function (x - 3y) over a triangular region defined by specific vertices. The transformation equations provided are x = 2u + v and y = u + 2v.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the integral and the transformation of variables, with some questioning the inclusion of the Jacobian in the calculations. There are attempts to derive the limits of integration and the transformed integrand.
Some participants have provided guidance regarding the necessity of the Jacobian and its impact on the integral's evaluation. Multiple interpretations of the limits of integration are being explored, and there is acknowledgment of potential errors in the calculations.
There are constraints related to the triangular region's vertices and the transformation equations, as well as varying interpretations of the limits for the integration variables.
tnutty
Use the given transformation to evaluate the given integral.
\int\int(x-3y)DA
R.
where R is the triangular region with vertices (0,0), (2,1) and (1,2) ; x = 2u + v , y = u + 2v
Trial :
Using the points given I came up with these equations for the triangle lines :
y = 2x;
y = 1/2x;
y = 3 - x;
Now just substituting x = 2u and y = u+2v I get this :
u = 0
v = 0
v = 3(1-u)
plotting this , I see that 0<= u <= 1 and 0<= v <= 3(1-u)
And from the original integral the integrand is x - 3y. Again substituting
for x and y with the given transformation coordinate for u and v I get :
(x-3y)DA = -(u+5v) dv*du
Now the integral becomes :
\int^{1}_{0} du\int^{3-3u}_{0} -u - 5v dvdu
In which I get the answer -4/5 which is not correct. Any help?
ok so the variable transformation sounds alright, but where is the Jacobian...? (as in the title)
as do you the variable change, you are effectivley rotating & squeezes the axes, dA = dx dy \neq dudv. So to preserve the original area you need to include the jacobian
Since :
The jacobian is :
|2 1|
|1 2|
= 2*2 - 1*1 = 3 ;
The the answer is -4/5* 3 = -12/5 ?
I still did something wrong I guess.
the limit for v is 0<y<1-u because v=1-u not 3(1-u) and you also need to include the jacobian in your equation, but you can just multiply the final answer you get by (3) instead of doing all your integrals after multiplying with the jacobian. And after doing this question I got -3 as the final answer.
  • · Replies 16 ·
  • · Replies 27 ·
