Jumping perpendicular out of a fast spaceship will retain your speed right?
Jumping straight up from a horizontally moving spaceship will not alter your horizontal speed; you will continue moving at the same velocity as the spaceship. Unlike jumping from an airplane, where air resistance plays a role, in space, there are no opposing forces acting on you immediately after the jump. To return to the spaceship, you would need to use a thrust mechanism or a tethered line. The principles of motion in space demonstrate that you maintain your momentum until acted upon by another force. Understanding these dynamics is crucial for grasping concepts like F=ma in a vacuum environment.
lamp23
If u stand on top of a spaceship, u will not be thrust backward?
U only do on top of an airplane because of air resistance?
So if u jump up out of a horizontally moving spaceship, after you jump out you are moving with the same horizontal speed as you were inside the spaceship? U just have to thrust downwards to get back?
Or use a tethered line to get back. There were four untethered space shuttle space walks where a thruster pack was used to allow the astronaut to move around.
http://en.wikipedia.org/wiki/Extra-vehicular_activity
Yes, that is exactly correct. Thinking about space dynamics is the best way to understand F=ma. You will continue to have the same velocity until acted on by some outside force (jetpack, tethered line). Its a bit hard to fully grasp here on earth, because we are constantly acted upon by various forces. (Gravity, pressure, wind resistance, etc.)
lamp23 said:
1) If u stand on top of a spaceship, u will not be thrust backward?
2) U only do on top of an airplane because of air resistance?
3) So if u jump up out of a horizontally moving spaceship, after you jump out you are moving with the same horizontal speed as you were inside the spaceship?
4) U just have to thrust downwards to get back?
1 - Top?
2 - Air resistance [STRIKE]and gravity[/STRIKE]
3 - Yes
4 - Down?
Mother nature did not endow ur spaceship witth the gift of absolute rest, so yes, relative to the ships frame you will go 0 mph after jumping out of it.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
