Keeping a UK house cool without air conditioning
  • Context: HVAC
  • Thread starter Thread starter sophiecentaur
    Cool Summer Tips
41 replies · 13K views
Homework Helper
There are a lot of strategies that can help to avoid it being total hell indoors in this hot weather.
We've had many threads about Air Con and Air Coolers but these things are not widely used in the UK and it's too late to contemplate AC because they've all been sold! There are other ways, though.
It's hard to realize just how much the fabric of the house heats up, whatever you do with doors and windows. The received wisdom seems to be to shut all doors and windows and to close curtains. It certainly works in downstairs rooms for us. Some idiot members of the Great British Public were interviewed on TV and said that strategy is "rubbish" and that the Met Office had no idea! That system works well but you can do better by closing internal doors and not using fans in unoccupied rooms. The heating effect of a poorly insulated house seems to be actually more obvious than the heat loss in winter. Ceilings can get noticeably hot during the day and I've found that avoiding the use of a fan helps to reduce heating of the room air (no convection with heat source at the top)
A crazy thing that I have noticed is that, despite a good flow of cool nighttime air, the room still feels hot due to radiation from the ceiling and walls. The once popular hot air heating systems lost credibility when it was realized that the cold walls made a room feel far cooler than the air temperature would suggest. Same thing but just the other way round. Radiation counts.
I was wondering if anyone has other pet methods for survival (apart from going to the local library all day).
Fan in a first floor window blowing in the house and a fan in the attic blowing outside? Put ivy on your outside walls to block the radiation?
sophiecentaur said:
Radiation counts.
Shade trees? Other heat sinks? And, "it's not the heat, it's the humidity." What've your dew points been running?
Wow, it must be hot indeed in Europe. It has been hot here in North America too.
You need to consider the time constant of the heat stored in the structure and the contents. I think the traditional folk rule is 72 hours. Therefore, you can't compare your tactics today with the results today. Keep a log and see if those good practices make it somewhat better 3 days later.
Poorly insulated house is the root of most comfort problems. You could paint the roof and walls white to reflect some of the suns radiant heat.
I once spent a summer in a US Air Force barracks without working air conditioning. Typical summer outside temperatures were nighttime low of 60 to 70 deg F, and daytime high of 100 to 110 deg F. The building was concrete block painted white on the outside. It stayed comfortable inside after we convinced everybody to shut down the ventilation blower during the day, and run it all night. The humidity, at least, was low. They couldn't fix the AC in summer, but waited until the following winter.
Even if the attic is insulated, forced attic ventilation is effective. Put a good-size (24 in.?) exhaust fan in one wall near the peak. Run it during the day to keep the attic temp down, and if cool at night keep it running with the door open between attic and living space to cool everything (open a few windows). In the US they are even available with a built-in thermostat. Put the fan on the leeward side of the prevailing winds.
If the exterior walls are not insulated, insulation can be blown in from the outside without major disruption. It's even a do-it-yourself job if you can do light carpentry work, can draft an assistant and don't mind working on a ladder.
Except for nights. When it's about the cool night air, no fan is enough.
Maybe I can add something useful to this topic after all. We tend to put our holiday to September. This way we can stay in the air conditioned office when it is hot and we have a good chance for a holiday not ruined by excess heat.
I really can't understand summer holidays.
Also, we keep a tent at the garden for sleeping when it is hot. By ten at night it's already cool enough to sleep, while in the house it's still like hell because of the walls.
The tent should be moved in every few days so it won't hurt the grass.
Ps.: just noticed that what I wrote is not really about keeping the house cool... Sorry. We gave up on that.
Circulating air through the roof void sounds a good idea but I don't think it's good to take air from the main house volume. That would involve pulling hot air into the house. Our present strategy of keeping doors etc. closed results in our internal temperature (downstairs) being at least 5C below outside. But the outside air temperature is a lot lower than the roof tiles get with sun on them. It would, indeed, be easy to instal and two fans would allow a choice of flow direction to match the wind direction and keep the fabric as cool as possible.
My house is a'dormer' design so the loft space is an awkward shape and very restricted to work in so experiments with extra insulation are not a very attractive idea. I need a helpful trained monkey to do all that stuff.
The UK government is very half hearted about help with energy saving. They have 'initiatives', every so often but they are mainly window dressing and I have not qualified for one reason or another, when I have investigated. The Feed In tariff for PV installations was good if your house (and you) fitted the requirements but all the benefits were paid for by the rest of the Energy consumers. More window dressing to make a past government look green.
The humidity outside here has been quite respectable - below 30% when the temperature is over 30C. We spent a couple of weeks around New York and the humidity made living without AC pretty bad at times.
Actually, it's another topic but I was wondering just how good the available humidity meters are. The basic principle seems a bit 'hopeful' to me for accuracy.
Although I do have an A/C unit, it's a bit small at 600 watts, so I do have to be mindful of heat sources.
I discovered last week that one room in particular got much warmer than the rest of the house, did some IR thermal scanning and found it was mostly due to a single window. It's 2 m2, and by my rough calculations accounts for 25% of my total heat flow. So I hung a large aluminized tarp to shield it. It seems to help a lot.
Today it's supposed to be 99°F/37°C, so I may turn on my attic fan. It's a 12 volt experiment left over from last year, and isn't permanently wired.
Currently, it's about 9 am(savings time, so 8 am in real time) in the morning, and the temperature outside is the same as in. About 72°F/22°C.
Attic temperature is 70°F/21°C, so it appears I have a bit of time left.*
Crawl space temperature is a surprising 67°F/20°C. I'd have thought it would be much cooler than that.
*Done!
As soon as hotter outside than in, Windows shut, curtains closed, 'occupied' rooms' fans running during day.
Soon as outside temperature cooler than interior, open curtains on shaded side, open windows, fire up the BIG air-mover to stir the air from the heat trap in stair well.
Despite desk and wall fans in bedroom, still slept 'sweaty starfish' mode on bath towel on top of bed.
Cool enough to sleep comfortably around dawn.
Rinse and repeat...
Don't watch youtube on $400 lenovo laptops.
Although I didn't state it, I was trying to indicate that during daytime the attic was to be ventilated while isolated from the rest of the house. During cooler nights, you can use the same fan to draw cool air thru the house by opening the door to the attic.
Sorry for the ambiguity.
Tom
I once owned a house in Houghton, Michigan. The roof was poorly insulated, so it was hot in the summer, and had major ice dams in the winter. It had a cathedral ceiling (no attic), so adding insulation was not possible, even if I had a skinny trained monkey helping. So we added insulation to the outside of the roof. Invited a bunch of friends and victims to a roofing party. Stripped off the existing shingles, put down a 2" layer of foam, laid 2X4's on top of the foam, nailed the 2X4's to the rafters using 6" long pole barn nails, put 1/2" plywood on the 2X4's, tar paper, and shingles. The 1.5" air gap between the plywood and the foam, combined with soffit and ridge vent, did an excellent job of ventilating. The house was very noticeably cooler in hot weather, and the ice dams were completely eliminated. And we got the job done in one weekend, except for minor touch up and painting.
Side note: American 2X4's are a standard lumber size. Many years ago, they were 2" X 4", then 1.63" X 3.63", and now 1.5" X 3.5" in cross section.
Interesting story. External added insulation is rare in the UK but I have seen examples. The reason, I think, is that the weather (up til now) has actually not been extreme enough and the modification is not cheap. There would be another difficulty in my case as we are semi detached and it would spoil the look of a well matched pair of cottages. Planning authorities in some areas would forbid it, too, despite the advantages.
In the end, I think I will need to bite the bullet and get the roof sorted with internal insulation by paying someone else to do it. (Ouch)
Well, that was interesting.
The fan made things worse!
I think it's because the exterior surface of the roof's temperature was 68°C/154°F, and that's where half of the intake air was coming from.
The other half of the intake air was ambient exterior temperature: 29°C/85°F
Just guesstimates on the proportions of course. It's much too hot to do anything more than eyeball things in this kind of weather.
Anyways, this is good to know.
Hopefully, we have some more nasty hot weather again tomorrow, so I can continue this experiment.
Obligatory graph:
The attic fan could be pulling some outside air in thru the living area. But that peak around 40000 seconds is only 0.36°C and the following downward trend, staying below outdoor ambient for 4Hrs, indicates some unaccounted hidden factors. (How does a sealed box decrease in temperature while being in a hotter ambient?)
Around Noon to 1pm of the first day for instance, perhaps the Sun was hitting some windows. There is a hint of the same on the second day.
p.s. The thermal time lag (outdoor to indoor) appears to be 2 to 3 Hrs. Is the roof facing East, with perhaps partial shade about 4pm?
I ran a garden hose up to the roof and placed three yard sprinklers along the peak.
Around noon and a a couple times mid to late afternoon i turn them on for five or ten minutes.
I see steam coming from the hot shingles and feel a slight difference in radiant heat inside the house.
I'm not instrumented so it's un-scientific
but it's quite a visual effect and the talk of the neighborhood.
I will add an attic fan when up there this winter wiring a new room. Maybe an attic temperature meter, too.
old jim
hmmmm... None of this makes any sense to me. I suspect it's mostly my fault, as I should have repeated that I do have an A/C unit in operation, and the internal temperature should be ignored. Consider it a "baseline".
Interestingly, the outside temperatures were both within 1°C of each other for days 1 and 2.
Also interesting, is that even though the attic exhaust fan was run at opposite times of day, the attic temperatures were also within 1°C of each other.
This indicates that the exhaust fan had near zero effect.
I suspect this is due to the area of the roof/ceiling of ≈84 m2, along with a solar irradiation factor of 1000 watts/m2, yields 84,000 watts.
My guess is that my attic system is currently designed for natural convection, and would require more modification than just a fan to fix this.
New obligatory graph, with less noise, and more information:
There be very tall trees to the south and west of my house.
I have 3 roof-peak vents, and about a dozen soffit vents. If you do install an attic fan, I would recommend not leaving open any spare roof-peak vents, as they kind of negate that type of improvement, IMHO.
OmCheeto said:
84,000 watts
12V fan, likely not a high volume air mover.
Probably some folks here could calculate what air flow rate is needed to keep the exhaust temperature to, say, a 5°C rise. Any takers?
When we bought our house and garage, they were grey with very dark shingles. The very large garage had no insulation.
When we got around to painting the house and getting it re-roofed we went with very light colors which made a big difference in how things heated up in the sun. (Oregon's summer is usually very cloud free, so the sun can be very intense for a long time.)
During summer I keep the kitchen stove hood fan going to remove heat being produced by the refrigerator, cooking activities and from the neighboring laundry room.
This makes a noticeable difference.
I eventually got around to renovating the garage (shop, fish room, office).
The garage is built in a concrete slab, which provides a cooling surface.
I insulated all exterior surfaces (from the inside), put a plywood floor on the bottom of the triangle things (whatever they are called) that support the roof (storage space) and put another layer of insulation under the ply wood floor.
I put a large attic type fan into on end of the roof which I have controlled by a programmable timer (it can also be set to run on a thermostat). This serves two purposes. During cold times it comes on occasionally to exchange air and remove humidity from the fish tanks.
As the weather heats, up I increase the fan's on times until I get to the point of having it on all the time.
I can control the source of the air the fan is drawing in by opening closing doors. With the doors closed, relatively little air is drawn through the lower areas of the garage. Instead it seems to come directly into the garage through numerous small leaks, thus drawing out any heat that gets through the roof insulation. The insulation under the attic floor isolates this heat from the main part of the garage.
I also installed an AC in the fish room in case things got too hot for the fish, but it is almost never used.
I was much more limited in what I could do with the house (added some insulation in some roof areas, besides the shingles and painting).
Without AC going, the garage is much more comfortable than the house, but we now have a couple AC units in the house for bedrooms.
I would recommend that they not bother trying to solve my problem, as my annual heating costs are around 26 times my cooling bills. Day 1 of the experiment cost me $1.30, according to my Kill-a-Watt meter. I think a better solution would be to add more insulation to the attic. Two birds with one stone!
Also, the fan is probably adequate. I'm guessing it has an throughput of 500 cfm. It's an 80 watt, 12 inch automotive radiator oil cooler fan. The problem is the undersized vent. I'm pretty sure it's just pretending to push air out. I was contemplating solutions to this this morning: Install a ground intake duct on the north side of the house. But it's not really worth my time, IMHO.
Currently, I'm doing non-A/C experiments. The heat wave broke here today.
I tried yesterday, but as soon as the temperature reached 77°F in my living room, I said to myself; "SCREW SCIENCE!".
Anyways, I removed the 80 watt fan from the attic and installed it where my old 400 watt furnace fan was mounted to an exterior door.
I used it to circulate cool night air through the house before I discovered A/C. (about 5 years ago)
It worked great, as long as night time temperatures dropped into the 60's.
If not, I laid in bed all night under a single sheet, with a spritz bottle.
Evaporative cooling is the bomb.
Except for the fact that you wake up every two hours, and have to re-spritz the sheet.
hmmm...
I think I've exposed myself.
Although I do 99% of my calculations in SI, I still think in Imperial units.
My bad.
My bad.
Sez who? BTU's rule !
The only reason I used BTUs, is because I knew my house had a "heat capacity" of ≈6000 BTU/°F.
Today I calculated that that is about 3 kwh/°C.
Goodbye, BTU.
Sorry that I never really got to know you. :oldfrown:
ps. Today I started collecting thermal data in "Celsius", as I've collected so much data in the last few days, that I'm sure I'd know by now that because it's going to be "38" [100°F] on Tuesday, it should mean something. (still nope)
pps. Today's hi temp is expected to be only 28° [82°F]. Currently 24.6° [76.3], at my house.
I still have to double °C subtract 10% and add 32. Getting pretty quick at it .
Dont have a similarly simple algorithm for the other way though.
°F to °C
Subtract 32
Halve it
Add 10%
Ans is 1% low, "Good enough for Government work!"
Without changing the structure of the house, there are a few things you can do to keep it cooler in the summer.
(1) Put shades in all the windows during the day, preferably with a white color facing out. Solar radiation through the windows will heat the house. Shades will reflect and block much of it.
(2) Close the windows when the outside temperature exceeds the inside temperature.
(3) Roll the shades up when the sun goes down and the exterior temperature drops below the inside temperature.
(4) Open the windows when the outside temperature drops below the inside temperature. Use fans to blow air out the upstairs windows and suck it in through the downstairs windows.
(5) Use a dehumidifier to pull water out of the air. Lower humidity allows sweat to evaporate faster and cool you better.
Long term you can plant deciduous shade trees on the southern sides of the house. Why deciduous? Because the leaves shade the house from the sun in the summer to make it cooler, but you want the sun to hit the house in the winter when the leaves aren't on the trees.
With new construction, putting in geothermal heat pumps can pull some of the heat out of the house. Attic fans to remove the heat build up in the attic so you get less radiation down into the inhabited rooms, and said rooms can radiate heat into the attic. (Note that a very well insulated house isn't going to allow transfer of stored heat very well.) Paint the roof and sides white. (Too bad we don't have a venetian blind roofing and siding where you could have white on one side for the summer cooling, and black on the other side for winter heating.)
Putting the building underground also makes it much easier to keep cool. Remember Luke Skywalker's home on Tattooine?
True if local codes permit that. Underground residences may have difficulty meeting the requirements for multiple fire exits.
I've done this before, and I reinstalled it again a couple of hours ago.
I've turned in on for about 3 minutes, at the top of the hour.
As indicated by my earlier graph, I get rooftop sun in the morning, and zero in the afternoon.
Though I plan on maintaining the hourly "watering", to see the effects.
It was supposed to be 100°F/38°C today, but the hazy cloud cover is a bit more than normal, so I don't think we'll hit that today.
Haven't seen any steam yet.
I have spare shingles from my DIY roofing project. I've been considering building a mini-me roof in the driveway, with just a single shingle, tar paper, and 1/2 inch[13 mm] pine board, with temperature sensors at each layer, but..., that sounded like a lot of work.
Yesterday, I successfully went the whole day without A/C.
I suspect it may have been because I was measuring temperatures in Celsius, and had not a clue how hot it was. :biggrin:
Doh! Top of the hour. Time for more measurements.
I've got to say the perceived wisdom of closing doors and windows seems a bit strange, its certainly not reflected in the architecture used in hot countries. With the windows closed the curtains should heat up nicely in the sun and act like a radiator. Perhaps its not actually the absolute temp. that's important a breeze helps our own cooling systems, I leave all my windows open and all internal doors, its quite a tall house and I get a sort of chimney effect. I also have a cellar which is always cool but digging one might not be practical. If I use fans I tend to put iced water behind them to get an evaporation cooling, you can get coolers that use this principle, though they are not brilliant. The best is to use one of those misters behind the fan, then it has a noticeable effect, even indoor water features could help, the Moors seemed very fond of the odd fountain. Plenty to drink is important, it seems sensible for the drinks to be cold, I know people say drinks like mint tea are cooling but I haven't been able to make sense of that yet.
I thought sweating inside a closed box was a form of torture.
