Kill my curiosity - Rolling a ball down a ramp, friction or no friction?
The discussion revolves around the effects of friction on a ball rolling down a ramp and onto a pavement, comparing two scenarios: one with friction and one without. Participants explore the implications of friction on energy loss, rolling motion, and the distance traveled by the ball.
  • Some participants propose that a ball rolling down a frictionless ramp will travel further because it does not lose energy to friction, while others argue that rolling objects can go further due to the conversion of energy into rotational motion.
  • One participant suggests that if the ball rolls without sliding on the ramp, no energy is lost due to static friction, which does no work.
  • Another participant questions how to determine the distance traveled based on kinetic and rotational energy.
  • Some participants note that the second ball cannot purely roll because the point of contact with the ramp has acceleration.
  • There is a claim that purely rolling objects do not lose energy to friction at the point of contact, as it is instantaneous and has zero displacement.
  • One participant asserts that friction inherently causes energy loss, suggesting that a ball on a frictionless path will travel further due to reduced resistance.
  • Another participant discusses the complexities of the contact point and the nature of friction, indicating that it is not instantaneous and involves electromagnetic forces.
  • One participant describes how the rolling motion affects the normal reaction force, suggesting that it opposes the motion of the body.
  • There is a mention of torque produced by friction being in the direction of angular velocity, raising questions about its effect on motion.
Participants express multiple competing views regarding the effects of friction on the distance traveled by the balls and the nature of energy loss in rolling motion. The discussion remains unresolved, with no consensus on which scenario leads to a greater distance traveled.
Participants highlight limitations in their understanding of energy loss mechanisms, the role of static versus kinetic friction, and the complexities of the contact point during rolling motion.
Dorbo
Hello people,
I have 2 scenario's. One is a ball rolling down a ramp with friction, onto pavement with friction. The other is a ball rolling down a ramp without friction, onto pavement with friction. Everything between them is the same except for the friction.
I think that having no friction will mean the ball will go further. I say this because you won't lose any energy to friction. The ball will only have translational energy, until it hits the pavement then a torque will be introduced, and this will cause it to start rolling.
On the other hand, with friction it will start rolling on ramp, and rolling things go further. But we will lose more energy due to friction. I don't know why, and i guess part of what i want to know is why do things that roll go further. We will lose more energy due to friction. SO I'm not sure how this affects each other.
What i want to know is which ball will travel further, and will there velocities at the bottom be the same?
I am not a physics student, but i have a taken 2 mechanics courses, and i know about angular momentum, moments of inertia, and angular velocity. I am really curious about this.
Thank you for your time.
Dorbo said:
Hello people,
Yes, The ball #2 will only have translational energy and in the process of its rotation speed increasing from 0 to [tex]\omega[/tex], much energy lose.
No. If it(#1) just roll and don't slide on ramp, then NO energy will be lost. it is because of static friction doing no work.
the smoth one's translational velocity is larger than the first ball at the bottom. As for the rotation velocity, they reversed. and their energies are same at the bottom.
In THEORY, they can roll for ever on plane with friction, because when the translational speed match up the rotation speed ( [tex]\upsilon=\omega R[/tex] ), there are no friction between the rolling ball and the rough plane.
if someone would do the experiment, I prefer the first ball (on rough ramp) will go further.
So from what the previous person said, i think it comes down to, how do we determine how far something goes with X amount of kinetic energy, and with an Y amount of rotational energy.
The second ball cannot purely roll as the point of contact of the ball with the ramp has an acceleration
While purely rolling a ball does not lose energy to friction as the point at which friction acts loses contact instantaneously and hence displacement is zero. Rolling objects lose energy for some other reason, which I am unable to recall.
Fiction causes loss of energy, simple as that. If you were to give a rotation to the ball on the frictionless ramp it will continue to rotate without loss of energy.
You can think of fiction as if the ramp was sticky. As the ball is rolling it sticks(slightly, it doesn't stop the motion) to the ramp. This is what allows the ball to start rolling in the first place.
If there is enough fiction the ball will come to a stop quickly and possibly even just stick there. A rolling ball has inertia though which will help it continue rolling.
You don't need a ramp for your experiment. Just roll two balls with one having some part of it's path being frictionless.
It's obvious that the the ball on the frictionless path will travel further because that is the whole point of friction. Friction resists the motion. If it resists it then it slows it down and if it slows it down then there must be a loss of energy.
@ashishsinghal: The point of contact is very complex and it is not instantaneous. It's not even well defined. Basically like minute Velcro. The fact that it has friction though means that you are losing energy.
Can you think of something that has friction and doesn't lose energy due to the friction?
From wiki
Friction is not a fundamental force but occurs because of the electromagnetic forces between charged particles which constitute the surfaces in contact. Because of the complexity of these interactions friction cannot be calculated from first principles, but instead must be found empirically."
So unless you can beat the electric force your "Contact" point isn't instantaneous(because this force doesn't need contact to act).
When a sphere rolls ,the surface in contact with the sphere &horizontal is depressed and the surface just in front of it is raised ,so when the rolling sphere strikes this raised surface the normal reaction instead of passing from center of mass ,passes through a little bit away in the forward direction of the motion.It therefore opposes the motion of the body.
Torque produced by friction is in the direction of angular velocity. How can it stop it?
  • · Replies 59 ·
  • · Replies 20 ·
