Kinematics: finding acceleration
The discussion revolves around calculating the acceleration of a 1000 kg weather rocket launched straight up, which experiences constant acceleration for 16 seconds before the motor stops. The altitude after 20 seconds is given as 5100 meters, and the user initially attempts to solve the problem using kinematic equations but makes errors in calculations. Feedback suggests correcting the time used in the distance formula and clarifying the effects of velocity and acceleration during the two phases of the rocket's flight. Additionally, the importance of treating the last 4 seconds of flight with the initial velocity from the first 16 seconds and accounting for gravitational deceleration is emphasized. The conversation encourages refining the approach to develop a comprehensive solution for the problem.
kapatter
I've been trying to figure this question out, and am now near on to pulling my hair out.
A 1000 kg weather rocket is launched straight up. The rocket motor provides a constant acceleration for 16 seconds, then the motor stops. The rocket altitude 20 seconds after launch is 5100 meters. You can ignore any effects of air resistance. What was the rocket's acceleration during the first 16 seconds?
In my panick for a solution, one thing I tried was this:
v = u+at,
= 0 +16a
= 16a
distance traveled during first 16 second
s= ut +(1/2) at^2
= 0 + (1/2) at^2 = (1/2) a 20^2 = 200a
total distance traveled after 20 second = 5100 m
5100 = 200a + 16a x4 -(1/2) x9.8 x4^2
264a = 5178.4
a = 19.61 m/sec^2 ...but obviously, this is incorrect. If anybody has any suggestions at all, I would be really grateful. Thanks!
You're on the right track, but making small errors in your math. First, in your initial calculation of s, you say that you want to calculate s after 16 seconds, and then plug in t=20 into the equation.
So fix that, and then make it clear what the velocity and acceleration are doing during the two time periods to give you the total.
I think you have a good start. The distance traveled during the last 4 seconds if I'm thinking right should be treated kinematically as the distance traveled with the Vi being the velocity after 16 secs subject to the decelleration due to gravity. That could be a delta Y. The other Y achieved during the first 16 seconds is 5100 less delta Y.
So keep on keeping on but develop an all at once closed form solution, that can be evaluated. This way logical vs computational errors can be eassily tested.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
