Kinematics: given 2 position vectors, time, and V of earlier
Given two position vectors, the change in time, and the initial velocity of a particle, one can calculate average velocity and displacement. Average velocity is derived from displacement divided by the change in time, while displacement can be determined directly from the position vectors. The discussion highlights that while average acceleration and final velocity can be calculated under certain conditions, they are not universally applicable without additional information. Specifically, the relationship for final velocity relies on the assumption of constant acceleration. Thus, the key quantities that can be reliably calculated are average velocity and displacement.
Dillon Keeler
If you know the position vectors of a particle at two points along its path, change in time between the two positions, and the particle's velocity at the earlier point, what quantities can you calculate?
a)average acceleration
b)final velocity
c)average velocity
d)displacement
My answer was all of the above because one can find
d) by just the two position vectors
c) by ( displacement / change in time )
b) by Vaverage= (1/2)(Vinitail+Vfinal)
a) by average acceleration = ( change in velocity / change in time)
however the answer is just c) and d). Am I forgetting to take something in consideration?
Your "b" is true only for a special case. It is not a generally valid relationship.
Do you know what is this special case? What is the condition to have this relationship?
Constant Acceleration?
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
