What angles can a tank aim at to hit a target on a mountain 10km away?
  • Thread starter Thread starter devanlevin
    Kinematics
To determine the angles at which a tank can aim to hit a target on a mountain 10km away, the problem involves kinematic equations considering only gravity. The tank's initial velocity is 500 m/s, and the target's coordinates are (10000m, 500m). The equations for horizontal and vertical motion must be combined, leading to a relationship involving both tanθ and cosθ. The discussion suggests solving for time (t) first instead of directly solving for the angle (θ) to simplify the calculations. This approach may help in finding a common expression to determine the required angles for the shot.
devanlevin
a tank shoots at a target on a mountain 10km away from it, the hight of the mountain is 500m the tank shoots at a speed of 1800km/h, at which angles can the tank aim?
this is a question in kinematics and the only force to take into account is gravity,
using
V(t)=Vo+at
X(t)=Xo+Vot+½at²
V²-Vo²=2aΔx
Vx=const=cosθ*Vo
Vy(t)=sinθ*Vo+at
Vo=500m/s
Xf=10000m
Yf=500m
knowing that the target is at (10000,500) i use the equation for X,
X(tf)=500cosθ*tf=10000m
tf=20/cosθ
Y(tf)=500m=500sinθ*(20/cosθ)-4.9*(20/cosθ)²
=1000tanθ-1960/(cosθ)²
now from here i don't know what to do, one equation with both tanθ and cosθ, how do i bring them to some common expression?? i have had a very similar quesion before which i too could not get past this point.
since i do not have T, i thought of using the 3rrd equation, but i don't see how i can
Instead of solving in terms of theta, why not try solving in terms of t first?
how would you do that
  • · Replies 20 ·
  • · Replies 17 ·
15K
