chimpz
- 7
- 0
(this is all in context to a java 2d object and is not homework related)
I have an object with velocity [itex]v[/itex] and position [itex]x[/itex].
Its acceleration is directly proportional to velocity squared ie [itex]a=k v^{2}[/itex].
Given the objects initial velocity [itex]u[/itex] and its initial position [itex]x_{0}[/itex] how would i work out its velocity and position at time [itex]t[/itex]?
I have tried integrating:
[itex]a = \frac{dv}{dt} = kv^{2}[/itex]
[itex]\int^{v}_{u} v^{-2} dv = \int^{t}_{0} k dt[/itex]
[itex]\frac{1}{u} -\frac{1}{v} = kt[/itex]
[itex]v = \frac{1}{\frac{1}{u} - kt}[/itex]
tbh I got a lot further while writing this post than I did trying to work it out before
trying to get the new position:
[itex]\int v^{-2} dv = \int k dt[/itex]
[itex]-\frac{1}{v} = kt[/itex]
[itex]v = \frac{dx}{dt} = -\frac{1}{kt}[/itex]
[itex]\int^{x}_{x_{0}}1\:dx=\int^{t}_{0}-\frac{1}{kt}dt[/itex]
[itex]x-x_{0}=-\frac{1}{k}\left[\:ln|t|\:\right]^{t}_{0}[/itex]
But you can't [itex]ln|0|[/itex] :/
So, without bounds:
[itex]x=-\frac{1}{k}ln|t| + c[/itex]
Now I'm stuck.
How would I update the location?
Also, how would I implement drag while the engines were on?
Part of my code:
Pleased with myself for using the itex tags for the first time :D
Edit: could this be considered a hw-type question?
So, without bounds:
Now I'm stuck.
Part of my code:
Code:
public void update(double delta) {
if (engines) {
double dv = Math.sqrt(2 * powerToWeight * delta);
Vector2f temp = dir.copy(); //dir is the direction of the engine's force
temp.scale(dv);
velo.add(temp);
double dx = dv * delta * 2 / 3;
temp = velo.copy();
temp.scale(dx);
loc.add(temp);
// TODO add drag
} else {
velo.i = (float) (1 / ( (1 / velo.i) - drag * delta ));
velo.j = (float) (1 / ( (1 / velo.j) - drag * delta ));
// TODO update location
