Kinematics - What do these variables mean?
The discussion focuses on understanding the kinematic equation x = Xo + v0t + 1/2at², specifically in the context of a projectile motion problem involving a body thrown vertically. The user attempts to calculate the initial velocity (v0) required for a body to pass a height of 9.8 meters twice in 4 seconds, using the acceleration due to gravity (a = 9.8 m/s²). The calculated initial velocity is 22.05 m/s, which differs from the textbook answer of 24 m/s, prompting a discussion on potential errors in the calculation or the textbook itself.
  • Understanding of kinematic equations in physics
  • Basic knowledge of projectile motion
  • Familiarity with the concept of acceleration due to gravity (9.8 m/s²)
  • Ability to solve algebraic equations
  • Review the derivation of kinematic equations for projectile motion
  • Learn how to apply the quadratic formula in kinematic problems
  • Investigate common mistakes in calculating initial velocity in projectile motion
  • Explore the implications of air resistance on projectile motion calculations
Students studying physics, educators teaching kinematics, and anyone interested in mastering projectile motion calculations.
kbn
first off, i don't completely understand what do the variables in the equation do:
x=Xo+volt+1/2at2
the exercise:
A body is thrown up vertically, it passes trough the height 9,8m twice. Time between those two passes is 4 seconds. Whats the starting velocity ?
i presume i have to do it with two equation systems? first off i'd have to calculate the starting velocity needed to get up and down in four seconds. Then i'd calculate the starting speed needed to get to the "seconds starting speed" at 9,8m and that would be the answer.
Bigthnx
x=x_0 + v_0 t + \frac{1}{2} a t^2
x is displacement at time t
x_0 is initial displacement
v_0 is initial velocity
a is acceleration (constant)
t is time
hint: a=9.8 m/s^2 in this case
oh.. new to PF.. welcome :smile:
great thanks for explaining the equation for me (y) everything seems much clearer now.
So i tried to solve it, but the answer isn't what its supposed to be =/ I mean, it different in the end of the book. Is the book wrong or am i ?
9,8=0 + Vo4 - 1/2*9,8*4^{2}
4Vo = 1/2*9,8*4^{2} + 9,8
Vo= (1/2*9,8*4^{2} + 9,8) / 4 = 22,05 m/s
According to the textbook the answer should be 24 m/s
Thanks again
  • · Replies 32 ·
