What Is the Correct Kinetic Energy of Rotating Tires?
The correct kinetic energy of rotation for four tires of an automobile traveling at 32 m/s with a radius of 22 cm and mass of 11 kg is calculated using the formula KE = 1/2 Iw^2. The moment of inertia (I) for a disk is 0.5 * m * r^2, which results in I = 0.5 * 11 kg * (0.22 m)^2 = 0.5324 kg·m². The angular velocity (w) is determined by w = v/R, yielding w = 145.45 rad/s. The total kinetic energy for all four tires is KE_total = 4 * (1/2 * 0.5324 * (145.45)^2) = 5630 Joules.
  • Understanding of rotational dynamics
  • Familiarity with the moment of inertia for different shapes
  • Knowledge of angular velocity calculations
  • Basic proficiency in algebra for manipulating equations
  • Study the derivation of the moment of inertia for various geometric shapes
  • Learn about the relationship between linear and angular motion
  • Explore the concept of rolling without slipping in physics
  • Investigate energy conservation principles in rotational systems
Students studying physics, particularly those focusing on mechanics and rotational motion, as well as educators looking to clarify concepts related to kinetic energy in rotating systems.
lew44
An automobile is traveling at v = 32 m/s and has wheels with radius R = 22 cm. Assuming that the wheels are disks which roll without slipping and have a mass m = 11 kg, what is the kinetic energy of rotation of the four tires in Joules?
w = v/R
The kinetic energy for each tire is then
KE = 1/2 Iw^2
There are four wheels.
I tried converting 32 m/s to rad/s for angular velocity. So 32m/s divided by .22m (radius) to get 145.45.
Then I squared that answer. I multiplied it by .5.
Then for I, I used mr^2 and got .5324.
I got 5631.648. Tried multiplying that by four and it didn't work.
I've tried entering
3 Incorrect. (Try 1) 5630
5 Incorrect. (Try 2) 5.6x10^2
7 Incorrect. (Try 3) 2.3x10^4
9 Incorrect. (Try 4) 22500
None of these were correct. I'm wondering where I messed up...
"Then for I, I used mr^2 and got .5324."
The wheels were assumed disks, and the moment of inertia of a disk is 0.5 mr^2.
ehild
  • · Replies 33 ·
  • · Replies 21 ·
  • · Replies 58 ·
