Klein-Gordon equation for electro-magnetic field?
27 replies · 12K views · last reply
Lojzek
Can we imagine electro-magnetic field in vakuum as a massless particle that respects
Klein-Gordon equation (instead of Electromagnetic wave equation)?
It seems to me that both equations are the same, except that the electro-magnetic field can have 2 possible polarizations (then we count them as 2 different particles?).
Yes. The EM wave equation for A^\mu is the KG equation of a massless particle.
Only having two polarizations is due to the masslessness.
However, note that because we do not observe longitudinal modes (which are allowed by the KG eqns) you have to include a constraint into the solution.
but the Klein-Gordon equation is a scalar equation. Are the two modes not coupled? They propagate independently each satisfying the (massless) K-G equation?
As a comparison, there is the Dirac equation. The 4 components each individually satisfy the K-G equation as well (for free particles, that is) but they are coupled by the Dirac equation and not independent.
All good and true... but you can decouple the Dirac equation by finding it's eigenspinors. This is what you do, e.g., when you perform a mode expansion of the field.
Every free relativistic field will satisfy the KG equation, as it merely expresses [tex]p^2 = m^2[/tex]. Note that [tex]\mathbf{E}[/tex] and [tex]\mathbf{B}[/tex] also obey the massless Klein Gordon equation. I think to get the KG equation for [tex]A[/tex] you need to be in the Lorenz gauge.
Ok. I get it. The components of A are in general coupled by the Maxwell equations. It is just by selecting a special gauge they are de-coupled.
Out from the dunce corner with my weekly dumb question. Looked up Klein-Gordon equations in wikipedia--nothing. Looked in my McGraw-Hill encyclopedia of Physics--nothing. Kindly generalize in words, no acronyms please, what those(or that) equation(s) is about.
klien gordon is kind of a relativistic Schrödinger equation. it uses energy squared is equal to the (momentum times the speed of light in vaccuum) squared plus the mass squared times the speed of light in vacuum to the fourth power, i think. and turns everything into waves and operators.
the electro magnetic equations can be found by comparing maxwells equations to each other. something like the laplacian of E equals the E double dot, where E is the electric field.
or something
[tex]\partial^\mu \partial_\mu \psi + m \psi^2 == 0[/tex]
Genneth made a small typo - it should read
[tex]\partial^\mu \partial_\mu \psi + m^2 \psi == 0[/tex]
or
[tex](\square^2 + \mu^2)\psi = 0[/tex]
[nrqed- you're too quick - I'm still editing - d*mn latex. It depends on your definition of [tex]\square[/tex]]
or
[tex](\Box^2 + \mu^2)\psi = 0[/tex]
Mentz made a very minor typo: there is no exponent of two on [tex]\Box[/tex]
:wink:
nrqed - for me
[tex]\square^2 \equiv -\frac{d^2}{dt^2} + \nabla^2[/tex]
Mentz114 said:
nrqed - for me
Ok. It's just that I have never seen this definition used in any book so it's not the standard definition, as far as I know. But I may be wrond and if you know of any book using that notation I would be interested to know.
Regards
nrqed,
it's true it is used differently in various texts. Itzykson&Zuber use your definition, but the Wiki page uses mine. I guess I&Z are more authoritative. Best to define just what one means by it, I guess.
M
I think Gordan spelled his name that way, although Google votes 100-1 the other way.
Mentz114 said:
nrqed - for me
Both signs are used in books.
The opposite sign
[tex]\square^2 \equiv +\frac{d^2}{dt^2} - \nabla^2[/tex]
is winning out recently, because it corresponds to the metric (1,-1,-1,-1).
The Gordon in Klein-Gordon and the Gordan in Clebsch-Gordan are two different people.
Here is a more direct question about this topic:
Is relativistic quantum mechanic also supposed to describe the dynamics of photons? Or are the similarities between equations concidental?
The opposite sign
Thanks for sending the details of that operator but I've been seeing such equations for years. Are there any physical/intuitive ideas associated with this one?
Normouse,
the square is called the D'Alembertian operator. More info here -
en.wikipedia.org/wiki/D'Alembertian
It should strictly be written like this ( note the factor c^2)
[tex]\square^2 \equiv +\frac{1}{c^2}\frac{d^2}{dt^2} - \nabla^2[/tex]
in which case, (as has been stated above)
[tex](\frac{1}{c^2}\frac{d^2}{dt^2} - \nabla^2)\psi = 0[/tex] means that [tex]\psi[/tex] is a field whose quanta travel at c.
You might say so :smile:
The whole first part of my book is devoted to this equation...
for instance chapter 1:
http://physics-quest.org/Book_Chapter_EM_basic.pdf
Regards, Hans
Thank you. I now recall that I knew that once.
RQM does describe the kinematics and dynamics of photons.
There are very few coincidences in physics.
This seems strange to me, since a straight wave in quantum mechanics implies uniform probability density and consequently uniform energy distribution (1 photon=h*f energy), while a straight electromagnetic wave implies energy distribution proportional to E^2, which oscilates.
Good news
Mentz114 said:
Normouse,
Wow! A wonderfully clear and straight answer with actual intuition and physical feel. (VERY UNUSUAL for you physicists--careful your physicist card might be in jeopardy((just kidding))). Thanks Mentz114.
Regards, Hans
Books sure have improved since I was an undergraduate. I hope to "line by line" it soon. Thanks for that site(with your book on it). I wish I didn't have to work.
