Lagrangian Method- 1st form? Zwangskraefte?
The discussion revolves around applying the Lagrangian method to a particle moving frictionlessly in a gravitational field inside a paraboloid described in cylindrical coordinates. The participant struggles to formulate the Lagrangian and seeks clarification on the term "Zwangskraft," which is identified as "constraint force." They are advised to express kinetic and potential energies in terms of a suitable coordinate system to derive the Lagrangian. The importance of conservation of energy and momentum in the context of the problem is emphasized, along with the necessity of understanding the physical situation to tailor the Lagrangian appropriately. Overall, the conversation highlights the challenges of mechanics and the need for a structured approach to problem-solving in Lagrangian dynamics.
clumsy9irl
Lagrangian Method-- 1st form? Zwangskraefte?
Mechanics will be the death of me. For some reason, I can do E&M, and particle stuff, but give me a pendulum, and I'm dumbfounded.
THat said, I'm working on some problems using Lagrangians, and the only book I have available to me is Goldstein (which is a bit above where I'm at, but helpful, once it clicks). The course I'm taking will count as my uppper level, undergrad mechanics course.
Anyway, I've got a problem. Supoose you have a particle that's moving frictionless in a gravitational field on the inside of a paraboloid (which is described in cylindrical coordinates as r= az.
How do I come up with the Lagrangian for this? If given one, I can usually figure out more on how to solve this, but it's stumping me. And another thing, I can't figure out what the english term for 'zwangskraft' would be, forced force? I'm supposed to find the size and direction of these forces, but I'm not really sure what it means. Eeep.
There's a note saying that I'm supposed to make it a requirement that energy and rotational momentum are conserved.
THat isn't heling me at all. Suggestions? ANy other suggestions for texts (that aren't too expensive), that might help me? My exam is in 3 weeks, and I'm lost.
clumsy9irl said:
Supoose you have a particle that's moving frictionless in a gravitational field ...
This seems to hint that the problem has a reduced number of dimensions (from 3). In other words, you aparently have a particle confined on some surface. The frictionless stipulation tells you that the Euler Lagrange expression is equation to zero (which gives you the Euler Lagrange equation).
clumsy9irl said:
... on the inside of a paraboloid (which is described in cylindrical coordinates as r= az.
This seems to be a description of the submanifold onto which the particle is constrained to move. However, that equation doesn't look like a paraboloid to me? In fact, I am even more confused about the bold vs. non-bold.
It's hard to say without a better understanding of the physical situation (because Lagrangian are Taylor-made). I will try to give you a general approach:
If this paraboloid is a 2-D surface, then devise some 2-D coordinate system that is capable of unambiguously describing the position of the particle on this surface. It is usually a good idea to do this so that either the kinetic energy or the potential energy only depends on one of the coordinates and not the other. Then, you need to express the two energies in terms of these new coordinates: T = (1/2)mv2 -> ?, V = mgh -> ?. Finally, of course, L = T - V.
If this is a 1-D parabolic curve, then the same as above, except that you don't worry so much about the coordinate dependence of T and V. You still need to express both in terms of the 1 coordinate that you chose. For instance, suppose the parabola is y = x2. Then
V = mgy = mg(x2)
and
T = (1/2)m{vx2 + vy2}
= (1/2)m{vx2 + 2xvx2}
= (1/2)m{1 + 2x}vx2
I'm not clear on what your submanifold is, though.
clumsy9irl said:
... I can't figure out what the english term for 'zwangskraft' would be, forced force? I'm supposed to find the size and direction of these forces, but I'm not really sure what it means.
From the sound of it, I would guess it means "constraint force." This is the same basic idea as the normal force you deal with in 1st semester physics. You don't approach the problem knowing it. In fact, the value doesn't matter to you except that it necessarily counteracts (usually) the weight (and any inertial forces) to balance the force and keep the particle on your submanifold. (In fact, this is just about the most important idea behind the Lagrangian formalism.)
You might try
www.dictionary.com/translator[/URL]
[QUOTE=clumsy9irl]There's a note saying that I'm supposed to make it a requirement that energy and rotational momentum are conserved.[/QUOTE]Well, you have problably have two mechanical energies: kinetic and potential. Since there's no friction, these should be conserved. The rotational momentum is conserved because you're dealing with forces that have a (scalar) potential energy associated with them.
Must be r^2=az
Unless it's a conical surface.
German has such a delightfully(?) dictatorial ring to it..
"Zwangskräfte" means, (in non-physics), "forces of subjugation"..:wink:
Yes, r^2= az. Typo that happened when bolding. Sorry :(
But thank you very much for your response. THat's exactly what I need, more of a step by step thought process on how to solve a problem like this. It all seems a bit clearer now :)
Hello! Let's say I have a cavity resonant at 10 GHz with a Q factor of 1000. Given the Lorentzian shape of the cavity, I can also drive the cavity at, say 100 MHz. Of course the response will be very very weak, but non-zero given that the Loretzian shape never really reaches zero. I am trying to understand how are the magnetic and electric field distributions of the field at 100 MHz relative to the ones at 10 GHz? In particular, if inside the cavity I have some structure, such as 2 plates...
