Lagrangian with springs and rotating wheels
The problem involves a cart with mass M on frictionless wheels, with a mass m suspended from a sloped top at an angle alpha. The discussion centers on writing the Lagrangian for the system and determining the frequency of oscillation of the suspended mass.
  • Participants discuss the formulation of the Lagrangian and the equations of motion. There are attempts to clarify the variables involved and the relationships between them. Some participants question the original poster's derivation and seek further explanation of their approach.
There is an ongoing exchange about the correctness of the Lagrangian and the equations derived. Some participants provide guidance on how to relate the angular velocity of the wheels to the linear motion of the cart and the suspended mass, suggesting a path towards deriving an ordinary differential equation for further analysis.
The original poster mentions that this problem was part of an exam and that they received partial credit, indicating some level of correctness in their approach. There is a focus on ensuring clarity in variable definitions and the need for further development of the equations to extract the frequency of oscillation.
mekrob
A cart of mass M rides on four frictionlesly mounted wheels of radius a and mass m'. The top of the cart is sloped at an angle alpha horizontally and a mass m is suspended from the top of the slope of force constant k. m slides without friction up or down the slope.
a) Write the Lagrangian.
b) What is the frequency of oscillation of the mass m'.
L= T-U
I(for disk/wheel)=1/2MR^2
L= 1/2 (4m'+M+m)\dot{x}_{1}^2 + 2I (\omega)^2 + 1/2m(\dot{x_{1}}+\dot{x_{2}} + 2\dot{x_{1}} \dot{x_{2}}cos(\alpha)) + mgx_{2}sin(\alpha) - 1/2kx_{2}^2
x1 = position of M
x2 = position of m
What is your question? If you want someone to verify that equation for you, it'd help if you explained how you got it.
This was on an exam (studying for the final). I wrote the same answer on the exam and the only mark the prof made was asking which are x_{1} andx_{2}, which I had forgot to clarify. I received most of the points for the question, so I assume it's right.
We don't do problems for you. Show what you've tried and we'll try to push you in the right direction. Start by writing the equations of motions, and try to figure out how you would extract a frequency from them.
Going through the Lagrangians, I got
\ddot {x_{1}} = \frac {gsin(\alpha) - \frac {kx_{2}}{m} - \ddot{x{_2}}}{cos(\alpha)}
and
(4m' + m + M) \ddot{x_{1}} + 2I\omega^2 + m(\ddot{x_{1}} + \ddot{x_{2}}cos\alpha) = constant
Again, I got these right on the exam, apparantely, I was just never good at converting this to \omega. Any help getting started?
You need to write \omega (ie, the omega for the rotating wheels, not the one you're trying to find for the oscillation of m) in terms of x_1, which will change your second equation. Then this will tell you that \ddot{x_1} is proportional to \ddot{x_2}, so you can substitute for \ddot{x_1} in the first equation to get an ODE for x_2 which should be easy to solve.
  • · Replies 21 ·
