Landau levels: Hamiltonian with ladder operators
The discussion focuses on the application of harmonic oscillator concepts to the Landau levels Hamiltonian. The Hamiltonian is expressed as \( H = \frac{1}{2m} p_x^2 + \frac{1}{2m} (p_y + e x B)^2 + \frac{1}{2m} p_z^2 \). Key transformations involve defining position and momentum operators using ladder operators, leading to a diagonalized form \( H = \hbar \omega (a^{\dagger} a + \frac{1}{2}) \). The relationship between the harmonic oscillator and the Landau level problem is established through the identification of a shifted equilibrium position and the frequency \( \omega = \frac{eB}{m} \).
  • Understanding of quantum mechanics principles, particularly Hamiltonians
  • Familiarity with harmonic oscillator models in quantum physics
  • Knowledge of ladder operators and their application in quantum mechanics
  • Basic concepts of magnetic fields and their effects on charged particles
  • Study the derivation of the harmonic oscillator Hamiltonian in quantum mechanics
  • Explore the application of ladder operators in quantum systems
  • Investigate the physical implications of Landau levels in condensed matter physics
  • Learn about the quantum mechanics of charged particles in magnetic fields
Physicists, graduate students in quantum mechanics, and researchers interested in the applications of harmonic oscillators and Landau levels in quantum systems.
Garlic
Landau levels in quantum mechanics
In short:
take the hamiltonian $$ H=\vec{Π}^{\,2} $$ with $$ \vec{Π}= \vec{p} + e \vec{A(x)} $$ and $$ A(x)=xB \hat{e}_y $$
and bring it in the form
## H = \frac{ Π^2_3}{2m} + \hbar \omega_c ( a^{ \dagger } a + \frac{1}{2} ##
I have brought the Hamiltionian in this form:
## H= \frac{1}{2m} (Π^2_3 + Π_{+} Π_{-} +e \hbar B)##
There is a point where I don't understand the given solutions.
They just say the ladder operators are defined as this:
## a^{ \dagger }/a:= \frac{1}{ \sqrt{ 2 e \hbar B }} (Π_1 \pm iΠ_2)##
I really don't understand how does this definition just fall off the sky. I've looked at many lesson notes from different universities, but they just defined it like this.
But I don't know how to derive this from the regular ladder operator formulas.
PS: there was a note from MIT,saying that the ladder operators of the total angular momentum are analogues for the $$ a/a^{\dagger} $$ ladder operators. Maybe the solution involves just replacing an operator with another?
$$ a= \frac{1}{ \sqrt{2} } (\frac{x}{x_0} +i \frac{ x_0 p }{ \hbar } $$
Dear PF,
I hope I've formulated my question understandable enough.
Thank you for your time,
Garli
The trick is to use your intuition from the usual harmonic oscillator. I assume you have probably seen the simple harmonic oscillator in your course if you are already doing Landau levels; to review, your Hamiltonian is
H = \frac{p^2}{2m} + \frac{1}{2} m \omega^2 x^2.
The solution comes from defining
x = \sqrt{\frac{\hbar}{2 m \omega}} \left( a + a^{\dagger} \right), \qquad p = i \sqrt{\frac{\hbar m \omega}{2}} \left( a - a^{\dagger} \right),
after which the Hamiltonian becomes
H = \hbar \omega \left( a^{\dagger} a + \frac{1}{2} \right).
Then using the commutation relation [a,a^{\dagger}] = 1, you can find the spectrum of this Hamiltonian.
How does this relate to the Landau level problem? Well, let's write out the full Hamiltonian:
H = \frac{1}{2m} p_x^2 + \frac{1}{2m} \left( p_y + e x B \right)^2 + \frac{1}{2m} p_z^2.
The key point to notice is that p_y and p_z commute with each other and everything else in this Hamiltonian, so that the relevant part needed to diagonalize it is entirely in the fact that p_x and x do not commute. In fact, rewriting it as
H = \frac{1}{2m} p_x^2 + \frac{1}{2} \left( \frac{e B}{m} \right) \left( x + \frac{p_y}{eB} \right)^2 + \frac{1}{2m} p_z^2,
it looks just like a harmonic oscillator in the x coordinate but with a shifted equilibrium position, and a frequency \omega = eB/m. (Is this frequency a familiar quantity, say from the motion of a classical particle in a magnetic field?)
Can you see how to apply the harmonic oscillator solution to this Hamiltonian now?
