How Do You Apply Laplace Transform to an ODE with a Derivative of Time?
The discussion focuses on applying the Laplace Transform to the ordinary differential equation (ODE) given by y''(t') + 2y''(t) - 2y(t) = 0, with initial conditions y(0) = y'(0) = 0 and y''(0) = 0. Participants clarify that the challenge lies in transforming y''(t') while considering the derivative of time. Key insights include the importance of referencing standard Laplace Transform results for derivatives and the distinction between dependent and independent variables in the equation.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with Laplace Transforms and their properties
  • Knowledge of initial value problems in differential equations
  • Basic calculus concepts, particularly derivatives
  • Study standard Laplace Transform results for y'(t) and y''(t)
  • Learn how to apply Laplace Transforms to initial value problems
  • Explore the implications of variable transformations in differential equations
  • Investigate the relationship between dependent and independent variables in ODEs
Students and professionals in mathematics, engineering, and physics who are working with differential equations and seeking to deepen their understanding of Laplace Transforms and their applications.
Linder88
Member warned about posting without the HW template
The ordinary differential equation, with initial values,shall be solved using Laplace transform. The ODE looks like this
\begin{equation}
y''(t')+2y''(t)-2y(t)=0
\end{equation}
And the initial conditions are
\begin{equation}
y(0)=y'(0)=0, y''(0)=0
\end{equation}
The problem is with the first term in the ODE, how do I transform taking the derivative of t in consideration? I would be happy for an answer!
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
There are standard results linking the L.T.s of y'(t) and y''(t) to the L.T. of y(t). You can (and should) look them up in any table of Laplace Transforms. (PF Rules require that you show some effort before receiving help.)
I think you misunderstood the question, the problem is not to make Laplace transforms of y(t), y'(t) and y''(t) but of y''(t'). There's a certain difference because taking the next step in the solution is dependent of this question.
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
1. The homework template is required. In future posts, please do not delete it.
2. In your diff. equation, the dependent variables are y and y''; the independent variable is t. I would guess that the expression t' means ##\frac {d}{dt}(t) = 1##. This would mean that your DE is y''(1) + 2y''(t) - 2y(t) = 0, or equivalently, y'' - y = -(1/2)y''(1).
The only other thing I can think of is that t' represents some transformation of t.
3. Your begin and end commands used the wrong slash -- it should have been \, not /.
I thought your question contained a "typo", and that you had intended y'''(t), because I could not believe anybody would write y''(t') if t is the independent variable. Of course if t = f(w) is actually some known(?) function of another variable w---as suggested by Mark---then the question would make sense if t' means f'(w). On the other hand, if t' really does mean dt/dt = 1, then y''(t') is just some constant (i.e., does not vary with t), so its L.T. is just the L.T. of a constant.
Thank you so much for your answer, it all makes sense! All three points :)
