Laplace's Transform: Initial-value Theorem applied to the n-th derivative
The discussion revolves around proving that lims tends to infinity of sn+1F(s) equals f(n)(0+) under specific conditions. The initial-value theorem is acknowledged, with the participant noting that the Laplace transform of f and its first derivative can be handled under the assumption of continuity and exponential order. However, complications arise when dealing with the n-th derivative, as the participant expresses uncertainty about the treatment of initial values. They question whether to assume that all initial values, except for f(n)(0+), are zero. The conversation highlights the need for clarity on assumptions to properly apply the theorem to higher derivatives.
libelec
Prove that, under the right assumptions, lims tends to infinity sn+1F(s) = f(n)(0+)
I don't have a problem with the common initial-value theorem, under the assumptions that both f and f' are partly continuous and of exponential order. Then I can find that the absolute value of sF(s) tends to f(0+).
But for f(n)(t), the Laplace's transform is sn+1F(s) - [snf(0+) + sn-1f'(0+) + ... + f(n)(0+)].
Should I make the assumption that all initial values except for f(n)(0+) are equal to zero?
Anybody?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
