How accurate is pulse width as a measure of response time for a pin photodiode?
The discussion focuses on the accuracy of pulse width as a measure of response time for a pin photodiode, specifically the s5973 model. It highlights that the rise time is influenced by terminal capacitance, diffusion time of carriers, and carrier transit time. Despite having a calculated rise time of 0.35 ns, the user experiences a broader pulse of 20 ns when measuring a 10 ns laser pulse. Suggestions include verifying the actual pulse width, adjusting the reverse bias voltage, and checking for stray capacitances in the circuit. The conversation emphasizes that pulse width is a crude measure of response time, and better accuracy can be achieved with improved signal-to-noise ratio and appropriate bandwidth reduction techniques.
apuz
For a pin photodiode, risetime=bandwidth/0.35
i get ~3ns for s5973
will it be affecting the measurement of 10ns laser pulse?
How can i reduce the rise time?
apuz, Welcome to Physics Forums!
The response speed of a photodiode is a measure of the time required for the accumulated charge to become an external current and is generally expressed as the rise time or cut-off frequency. The rise time is the time required for the output signal to change from 10 % to 90 % of the peak output value and is determined by the following factors:
1) Terminal capacitance Ct and time constant t1 of load resistance RL
2) Diffusion time t2 of carriers generated outside the depletion layer
3) Carrier transit time t3 in the depletion layer
For exact details see section 3-2 of this application note:
http://sales.hamamatsu.com/assets/html/ssd/si-photodiode/index.htm
Hope this helps.
hi Bobby, thank you 4 your interest.
the link gives me a rise time of 0.35ns.Which seems not to create problems of broadening.But when we try to measure a 10ns pulse using this s5973, it is giving a broader pulse of 20ns. We did ensure the following:
1)1 Ghz oscilloscope
2)50 ohms coaxial cable
3)50 ohms dc coupling on oscilloscope
4)3.3 supply@ which terminal impedance is min
any help?
apuz, the first question I have is: How do you know your laser pulse input is 10nS? It may actually be 20 nS!
If you can be sure the input is 10 nS, you might try adjusting the reverse bias voltage on the APD. You might try to raise it up a bit while watching that pulse on the oscilloscope for any changes. Stray capacitances (unplanned) will spread out high risetime signals...check your circuit layout/groundplane. One more thing...you may get a new (different) s5973 and see what happens.
Sorry not much help. Last thought: contact Hammatsu applications engineers. They will be interested in solving this, I think.
the pulse width was measured by the people who installed it. They used a black box kind of thing and didn't reveal what it is.
"pulse width" is a very crude measure of effective response time - a bit like the Rayleigh Criterion for telescopes etc.. You can do much better than the 'rise time' accuracy if you have a good SNR or reduce your measurement bandwidth appropriately with synchronous detection etc.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 28 ·
