Can Lasers Be Used as a Viable Energy Source Despite Their High Power Output?
Lasers, despite their ability to produce terawatts of power, are not viable energy sources due to their energy consumption exceeding the output. The discussion highlights that lasers require significant energy input to generate light, and the high power output is a result of very short pulse durations. Devices such as the MPA-XL Femtosecond Terawatt Ti:sapphire Laser System exemplify this principle, where power does not equate to energy generation. Ultimately, lasers consume more energy than they emit, making them unsuitable as energy sources.
  • Understanding of energy versus power concepts
  • Familiarity with laser technology and types, such as Helium-neon lasers
  • Knowledge of pulse duration and its impact on power output
  • Basic principles of energy consumption in laser systems
  • Research the energy consumption metrics of laser systems
  • Explore the specifications of the MPA-XL Femtosecond Terawatt Ti:sapphire Laser System
  • Investigate alternative energy sources that utilize laser technology
  • Learn about the principles of power generation and energy efficiency in high-power devices
Engineers, physicists, and researchers interested in laser technology, energy systems, and the efficiency of high-power devices will benefit from this discussion.
towuzzi
if lasers produce so much power why can't we use it as an energy source
Science news on Phys.org
Well to get a laser beam you have to supply energy right? If laser is used as an energy source you are getting nothing but the same energy you had supplied, practically lesser perhaps...
Here are schematics of three laser devices; red laser pointer, green laser pointer and a Helium–neon laser. Where are the energy sources (power supplies) in the pictures?
Helium–neon laser:
http://www.olympusconfocal.com/java/henelasers/henelasersfigure1.jpg
some can produce terawatts of power so where do they get all that energy to feed into the laser
Power is not energy. Terawatt lasers produce very short pulses.
As others have pointed out, lasers are not a source of energy. The consume more energy than what comes out in the form of light.
  • · Replies 19 ·
10K
