Latches and flip flops - how is stable state defined?
  • Thread starter Thread starter Same-same
    Stable State
The discussion clarifies the definition of "stable state" in the context of latches and flip-flops, emphasizing that a stable state is one that persists even when inputs revert to neutral levels. It distinguishes between stable configurations and stable memory states, noting that a stable memory state is maintained without continuous input. The conversation also highlights the role of stability in electronic circuits, particularly in bistable circuits and Schmitt triggers, which utilize non-linearity and hysteresis to achieve stability.
  • Understanding of S-R latches and flip-flops
  • Familiarity with bistable circuits
  • Knowledge of hysteresis in electronic circuits
  • Basic concepts of input-output characteristics in digital electronics
  • Research the operation of S-R latches using NOR and NAND gates
  • Learn about the characteristics and applications of bistable circuits
  • Study the function and design of Schmitt triggers in noise reduction
  • Explore the concept of stability in electronic systems and its implications
Electronics students, circuit designers, and engineers interested in digital logic design and stability analysis in electronic circuits.
Same-same
Latches and flip flops - how is "stable state" defined?
My textbook and professor both make numerous references to "stable state" of a latch of flip-flop, but never actually define it.
It's not intuitive. For instance, if the present output Q is 0, and we input S=1 and R =0, the circuit's next state, Q+ , is 1, and this is a stable configuration, but the textbook says this is not a stable state.
So what does "stable state" actually mean in this context?
I'm not aware of how the application of a steady state 1-0 or 0-1 input to an S-R latch (using nor2 or nand2 gates) can result in an unstable state except during the period of transition. But I expect the textbook is correct and I am missing some information. Perhaps it is referring to the transient state during which the output is 1-1 (nand) or 0-0 (nor) due to propagation delays.
I'd need you to sketch the gate arrangement to be sure, but I think you will find that a state which exists only while it is forced by the continued presence of a peculiar input is considered not a stable state. A stable memory state is one that will be maintained even when the inputs revert to their inactive/neutral level (the STORAGE state).
I can't comment on any distinction re a "stable configuration" vs "stable state"
The word 'stability' can refer to several different things. This can lead to confusion.
Stability, in this context usually refers to a situation in which, when a small perturbation is introduced, a system will return to its original state. In electronics, you can get stability with positive feedback (as with a simple 'bistable' circuit - Google gives dozens of hits). Stability in this sense requires some non-linearity. Once the bistable circuit is in one state (i.e. the output is hi or lo) then the input signal needs to cross a certain threshold value for the state to change - then the output state will swing to the other stable state. So the input output characteristic will be a 'step'.
A Schmitt trigger is another circuit which has 'hysteresis' which is a decision making circuit that cuts out the effect of low level noise on a signal. Once the input reaches a certain level, the Schmitt 'decides' it's high enough in level so it 'flips', the input signal then needs to go to a significantly low level before it decides to flip back.
  • · Replies 28 ·
13K
