Laurent Series Expansion Centered on z=1
The discussion focuses on finding the Laurent series for the function f(z) = 1/((2z-1)(z-3)) centered at z=1 within the annular domain 1/2 < |z-1| < 2. The initial approach involves partial fraction decomposition, leading to the series representation for the term 1/(z-3). Participants discuss the need for corrections in the series expansion, particularly regarding the coefficients and factorials in the Taylor series. The conversation highlights the importance of careful algebraic manipulation to ensure accuracy in the series terms. Overall, the participants are working towards confirming the correctness of their derived series expressions.
ChemEng1
Find a Laurent Series of f(z)=\frac{1}{(2z-1)(z-3)} about the point z=1 in the annular domain \frac{1}{2}&lt;|z-1|&lt;2.
By partial fraction decomposition, f(z)=\frac{1}{(2z-1)(z-3)}=\frac{1}{5}\frac{1}{z-3}-\frac{2}{5}\frac{1}{2z-1}.
When \frac{1}{2}&lt;|z-1|&lt;2, \frac{(z-1)}{2}&lt;1.
Hence: \frac{1}{z-3}=-\frac{1}{3-z}=-\frac{1}{3-z+1-1}=-\frac{1}{2-(z-1)}=-\frac{1}{2}\frac{1}{1-\frac{(z-1)}{2}}
Therefore: \frac{1}{z-3}=-\sum_{n=0}^{\infty}\frac{(z-1)^{n}}{2^{n+1}}
And: f(z)=-\frac{1}{5}\sum_{n=0}^{\infty}\frac{(z-1)^{n}}{2^{n+1}}-\frac{2}{5(2z-1)}.
Is this complete? Is there something I could similarly do with the other term? I've tried but haven't been able to find anything that works.
I would try explicitly calculating a few terms of the taylor series of the second term and try seeing a pattern.
It's this, right? \frac{1}{2z-1}=\sum^{\infty}_{n=0}(-1)^{n+1}(z-1)^{n}*2^{n}
So the expansion would become: f(z)=-\frac{1}{5}\sum^{\infty}_{n=0}(z-1)^{n}[(-2)^{n+1}-2^{-n-1}]
I'm not too sure about the n+1 on top of the -1. I'm also not too sure whether there should be a factorial there somewhere.
You're right about the -1. It should be raise to n, not n+1. I mistakingly thought the index started at 1 instead of 0.
I'm pretty sure the coefficient of the (z-1) term is a multiple of 2 in this case.
You're correct, sorry for that. I was forgetting to divide by n! in the formula for a_n of a taylor series.
No biggie. So is the last expression the answer then?
I still think there are a couple of sign and index errors. Try going through your algebra again to find them (or to prove me wrong).
I think I figured the other fraction out:
\frac{1}{2}&lt;|z−1|&lt;2,\frac{1}{2(z-1)}&lt;1.
Hence: \frac{1}{2z-1}=\frac{1}{2z-1-1+1}=\frac{1}{2(z-1)+1}=\frac{1}{2(z-1)}\frac{1}{1+\frac{1}{2(z-1)}}=\frac{1}{2(z-1)}\frac{1}{1-(-\frac{1}{2(z-1)})}=\frac{1}{2(z-1)}\sum^{\infty}_{n=0}(-1)^{n}[2(z-1)]^{-n}=\sum^{\infty}_{n=0}(-1)^{n}[2(z-1)]^{-n-1}
That looks much better. I hope.
