Least Squares Derivation—Simple Algebraic Simplification
The discussion focuses on clarifying a step in the derivation of the least squares method, specifically the transition from the last step on page 7 to the final equation on page 8. The main point of confusion is regarding the denominator, which appears to be a difference of two terms rather than a sum. It is noted that the author incorrectly modifies the signs when simplifying the equation, leading to a misunderstanding of the denominator's structure. The correct interpretation involves recognizing that the sign change should reflect a minus sign in the denominator. This clarification is essential for accurately understanding the least squares derivation.
END
Hey, PF
I'm reading the following derivation of least squares, and I'm trying to figure out how the author went from the last step at the bottom of pg. 7 to the final equation (11) at the top of pg. 8.
[http://isites.harvard.edu/fs/docs/icb.topic515975.files/OLSDerivation.pdf]
More specifically, why is the denominator a difference of two terms? Aren't the terms in the denominator summed in the prior step?
I would expect the answer to be
b_1=\dfrac{\displaystyle \sum_{\textrm{i=1}}^{n}y_ix_{i}-\left(\frac{1}{n}\right)\left(\sum_{\textrm{i=1}}^{n}y_i\sum_{\textrm{i=1}}^{n}x_{i}\right)}{\displaystyle\sum_{\textrm{i=1}}^{n}x_{i}^2+\left(\frac{1}{n}\right)\left(\sum_{\textrm{i=1}}^{n}x_{i}\right)^{2}}
Note: I'm no statistician, but I thought you guys might be more familiar with this derivation.
I think you are right. The step only "divides both sides of the equation by the quantity in the large brackets on the left side" as the text states.
So, the sign doesn't change and will be the sum of the two terms in the denominator as you wrote out above.
But the the mistake is a few steps before that where the text reads "Multiplying out the last term on the right". The writer removes the brackets but only changes the sign for the first term of the brackets. It is supposed to be a minus sign in the denominator (as in a difference of the two terms).
Likes END
Thank you, TitasB!
Likes titasB
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
