Lennard-Jones Work: Calculating Equilibrium Position
  • Thread starter Thread starter Nacho Verdugo
    lennard-jones work
14 replies · 3K views
Nacho Verdugo
I need to calculate the work donde by the Lennard-Jones Law, considering:
F(r)=F0 [2(σ/r)13-(σ/r)7]
when approximating two atoms from infinity to the equilibrium position between both atoms
First thing I don't know how to calculate is the equilibrium position (x0) between two arbitrary atoms
I just integrated this force, considering
WAB=∫F⋅dr ; r=A to r=B
As I don't know the x0, I just integrate from A to B, to later analyze the result. Assuming A=-∞ and B=x0
W= ∫ F0 [2(σ/r)13-(σ/r)7] dr ; r=A to r=B
= integrating...
= 2F0σ13 ( r-12 /-12) - F0σ7 (r-6/-6) ; still need to evaluate
Considering that A=-∞, I finally obtain:
W= F0σ7/6 (1/x06)-F0σ13/6(1/x012)
Is it right until here?
kuruman said:
What is the force at the equilibrium position. What does "equilibrium" mean?
What are your limits of integration? Consider particle A already at the origin. Then calculate the work done by the force on particle B as it is brought from infinity to x0.
The statement of this problems is:
In diatomic molecules, the constituent atoms exert attractive forces between themselves at great distances and repulsive forces at short distances. For many molecules the Lennard-Jones law is a good approximation for the modulus of these forces.
$$ F(r)=F_0 \cdot [2(\frac{\sigma}{r})^{13}-(\frac{\sigma}{r})^7] $$
where r is the distance between the center of the nucleus of the atoms, ## \sigma ## a length parameter and ## F_0 ## a constant.
Determine the work to be performed by this force or by an external agent to approximate two atoms from infinity to the position of balance between the two.
- So, what I mean to equilibrium position is the position of balance between the two atoms, but there is no more information about that.
- The limits of integration, as I don't know the position of balance, are ## A=-\infty ## to ## B=x_0 ## (the so called position of balance).
- Didn't catch up the last advice
kuruman said:
How big is the force on molecule A when it is at equilibrium or, as you say, in balance with molecule B?
I guess it is zero right? I that way it is in equilibrium.
kuruman said:
Exactly. So at what inter-molecular distance r0 is the force zero?
I don't know :C I took a while to answer cause of that. I think it should be at a huge distance, right?
kuruman said:
It is simpler than you think. The force in general is
$$F(r)=F_0 \cdot [2(\frac{\sigma}{r})^{13}-(\frac{\sigma}{r})^7]$$
At r = r0 you have
$$0=F(r_0)=F_0 \cdot [2(\frac{\sigma}{r_0})^{13}-(\frac{\sigma}{r_0})^7]$$
Do you see what you have to do?
yes! with $$F(r_0)=0$$ I can actually find $$r_0$$ and later evaluate that value in the integral.
kuruman said:
Go for it! :smile:
thank you very much!:biggrin:
kuruman said:
Is there a question you wish to ask?
No thanks! I just made a mistake editing this.
