Lennard-Jones Work: Calculating Equilibrium Position
  • Thread starter Thread starter Nacho Verdugo
    lennard-jones work
The discussion revolves around calculating the work done by the Lennard-Jones Law when approximating two atoms from infinity to their equilibrium position. The force is defined by the equation F(r)=F0 [2(σ/r)13-(σ/r)7], and participants are exploring how to determine the equilibrium position and the work associated with this process.
  • Participants discuss the integration of the force to calculate work, with some questioning the limits of integration and the definition of equilibrium. There is a focus on understanding the force at the equilibrium position and how to find the distance at which this force is zero.
The discussion is ongoing, with participants providing insights and asking clarifying questions. Some have suggested methods to find the equilibrium position, while others are still grappling with the implications of the force being zero at that position.
There is uncertainty regarding the specific value of the equilibrium position, with participants acknowledging a lack of information. The integration limits are noted as extending from negative infinity to the unknown equilibrium position.
Nacho Verdugo
I need to calculate the work donde by the Lennard-Jones Law, considering:
when approximating two atoms from infinity to the equilibrium position between both atoms
First thing I don't know how to calculate is the equilibrium position (x0) between two arbitrary atoms
I just integrated this force, considering
WAB=∫F⋅dr ; r=A to r=B
As I don't know the x0, I just integrate from A to B, to later analyze the result. Assuming A=-∞ and B=x0
W= ∫ F0 [2(σ/r)13-(σ/r)7] dr ; r=A to r=B
= integrating...
= 2F0σ13 ( r-12 /-12) - F0σ7 (r-6/-6) ; still need to evaluate
Considering that A=-∞, I finally obtain:
W= F0σ7/6 (1/x06)-F0σ13/6(1/x012)
Is it right until here?
What is the force at the equilibrium position. What does "equilibrium" mean?
What are your limits of integration? Consider particle A already at the origin. Then calculate the work done by the force on particle B as it is brought from infinity to x0.
The statement of this problems is:
In diatomic molecules, the constituent atoms exert attractive forces between themselves at great distances and repulsive forces at short distances. For many molecules the Lennard-Jones law is a good approximation for the modulus of these forces.
$$ F(r)=F_0 \cdot [2(\frac{\sigma}{r})^{13}-(\frac{\sigma}{r})^7] $$
where r is the distance between the center of the nucleus of the atoms, ## \sigma ## a length parameter and ## F_0 ## a constant.
Determine the work to be performed by this force or by an external agent to approximate two atoms from infinity to the position of balance between the two.
- So, what I mean to equilibrium position is the position of balance between the two atoms, but there is no more information about that.
- The limits of integration, as I don't know the position of balance, are ## A=-\infty ## to ## B=x_0 ## (the so called position of balance).
- Didn't catch up the last advice
How big is the force on molecule A when it is at equilibrium or, as you say, in balance with molecule B?
I guess it is zero right? I that way it is in equilibrium.
Exactly. So at what inter-molecular distance r0 is the force zero?
I don't know :C I took a while to answer cause of that. I think it should be at a huge distance, right?
It is simpler than you think. The force in general is
$$F(r)=F_0 \cdot [2(\frac{\sigma}{r})^{13}-(\frac{\sigma}{r})^7]$$
At r = r0 you have
$$0=F(r_0)=F_0 \cdot [2(\frac{\sigma}{r_0})^{13}-(\frac{\sigma}{r_0})^7]$$
Do you see what you have to do?
At r = r0 you have
yes! with $$F(r_0)=0$$ I can actually find $$r_0$$ and later evaluate that value in the integral.
Go for it! :smile:
kuruman said:
Go for it! :smile:
thank you very much!:biggrin:
Is there a question you wish to ask?
No thanks! I just made a mistake editing this.
