Light Interference Wave Equation - Assumption
9 replies · 3K views
elemis
In question.
To be clear it's part (vi) that's unclear to me.
In order to ignore the cosine term it has to reduce to 1. This can happen, only if k(x1+x2)/2 = ωt
Is this a correct assumption ?
Also, it is known that k = 2∏/λ and ω=2∏/T
However, I'm trying to think in what way these two components could be equal but I can't get it.
Could someone give me some help, please ?
For a long exposure, you average y^2 over time - the constant phase in the cosine does not matter for the average.
I really don't understand what you mean. Could you please break it down for me ?
I really do appreciate you taking the time out to help me.
A photograph collects light over a period of time.
The lightness in the photo depends on the intensity of the incoming light and the time of the exposure.
He's telling you to find y^2, then average it over time.
This gives you a function of position alone - which will be what the photograph shows.
When you do this - the terms you are worried about will cancel out.
Do you know what y=?
Do you know how to square a function?
Do you know how to average a function?
I can do the first two but not the last one. How do I average a function over time ?
EDIT: Why do I need to find y^2 ? Is it because intensity is directly proportional to Amplitude^2 ?
Did you read the links? The second one tells how to handle the average of a periodic function - what does it say to do?
I've carried out the steps for the time average for cos2x for limits 0 to T.
I've gotten : [itex]\frac{1}{T}[/itex][[itex]\frac{1}{2}[/itex]T+[itex]\frac{1}{4}[/itex]sin2T]
What do I choose to be T in this case ? Infinity ?
But it is not exactly cos2x that you have to average is it? x(t)=?
The trick with time averaging square trig-functions is to choose your interval carefully - if you let T be any integer number of quarter cycles, the average will make sense easily. I usually pick a singe period for T.
http://hyperphysics.phy-astr.gsu.edu/hbase/math/defint.html (3rd panel down)
