Can Two Airships Achieve Superluminal Speed with Elastic Material?
  • Thread starter Thread starter Strategiest
    Speed Superluminal
Strategiest
If we have two airships going at speed 0.6c in the opposite directions. then they will be separated at a speed higher than light.
let's name the airships , A and B
My question is , Let's say we have the two airships pull an elastic material.
take a point of the material on Airship A name it a , and a point on airship B. name it b. if they go at a speed close to light , then point a and b will be going at a speed faster than light ?
If so. then shouldn't all the points on the elastic material be going at a speed faster than light ?
You don't add relativistic speeds in the same way you do with everyday speeds.
V = \frac{v+u}{1+\frac{uv}{c^{2}}}
Let v = 0.6c and u = 0.6c, that gives V = 0.88c, so they aren't moving apart at a speed greater than light, but less than light.
Besides...
If the spacecraft are going .6C, then quite obviously, the fastest any part of the material will be going is .6C - right where it is connected to a spacecraft .
And...
Also quite obviously, a point at the center of an elastic band is stationary wrt where the stretching started. Try it with a broken rubber band - put a mark at the center and pull the ends apart. The mark doesn't ever move.
Thank you.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
