What is the Error Term for Computing the Limit of a_n=n^(1/n)?
  • Thread starter Thread starter akoska
    Error Limit Term
The discussion revolves around computing the limit of a_n = n^(1/n) using the binomial theorem and error term analysis, rather than relying on logarithmic properties. The error term, defined as |a_n - L|, is expected to approach zero as n increases. Attempts to apply the binomial theorem have been challenging due to non-integer exponents. Comparisons between a_{n+1} and a_n are explored to demonstrate that these terms converge to zero, suggesting the application of the Squeeze Theorem. The conversation emphasizes the need for a rigorous approach to establish the limit without logarithmic shortcuts.
akoska
Compute the limit a_n=n^(1/n) without using the fact that lim log a_n=log lim a_n. Instead, we're expected to solve this using binomial theorem and the error term.
na
Well, the error term = |a_n - L| which is expected to go to zero. I tried using binomial theorem on ((n-1)+1)^1/n with no luck. Also tried squeeze theorem.
hint
The binomial theorem is not obvious since you do now have whole number exponents.
Here is an attempt:
a_n=n^{1/n}
a_{n+1}-a_n = (n+1)^{1/(n+1)}-n^{1/n}
<(n+1)^{1/n}-n^{1/n}
and a_{n+1}-a_n > (n+1)^{1/(n+1)}-(n)^{1/(n+1)}
Showing that these comparitive terms go to 0 as n goes to infinity may use the "Binomial Number" expansion. Then, Sandwich Thm applies.
http://en.wikipedia.org/wiki/Binomial_theorem
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 16 ·
