Limit in multivariable calculus
The discussion focuses on evaluating the limit of a function as (x,y) approaches (0,0), specifically examining the expression involving square roots. A participant initially miswrote the function, leading to confusion about its definition. They explored various methods, including variable substitution and polar coordinates, but struggled to find a consistent limit. The conversation also addresses the validity of proving a limit does not exist by demonstrating different limits along different paths. Ultimately, if two paths yield different limits, it confirms that the original limit does not exist.
Gauss M.D.
Examine lim (x,y) -> (0,0) of:
\sqrt{x^{2}+1} - \sqrt{y^{2}-1}
\frac{\sqrt{x^{2}+1} - \sqrt{y^{2}-1}}{x^{2}+y^{2}}
Tried variable sub:
\sqrt{x^{2}+1} = a, \sqrt{y^{2}-1} = b
\frac{a - b}{a^{2}-b^{2}}
(a -> 1, b -> 1 as x,y -> 0)
Still nasty
Tried polar coordinates:
\sqrt{1 + r^{2}cosθ} - \sqrt{1 - r^{2}sinθ}/r^{2}
But I can't find a way for this limit to exist (which it is supposed to do according to the answers).
I think I got it. Conjugate rule...
Are you sure there's not some typo here?
##\displaystyle \sqrt{y^2-1\,}\ ## is only defined for |y| ≥ 1 .
Yeah, meant to write 1-y^2. But I figured it out anyway :)
Although I still have something I want to make clear: Say I wanted to show that a particular limit does NOT exist, for example:
xy^{2}/(x^{2}+y^{4})
Is the following valid?
Let y = x:
x^{3}/(x^{2}+x^{4}) = x/1+x^{2}
Which is 0 as x,y -> 0
Now let y = \sqrt{x}
x^{2}/(2x^{2})
Since I have found a path to the origin with an undefined limit, does that mean I have proven that the original limit does not exist?
Note by SammyS (Mentor):
The following was included a post which was otherwise an exact duplicate of this post.
I'm placing the extra text here because the other post appears in a thread which has been deleted.
Sorry, I meant, is it sufficient to find two curves with DIFFERENT limits?
I.e. let y = x and you have the limit = 0, and y = sqrt(x) and the limit = 1/2
My first comment: Be careful with parentheses. You have unbalanced parentheses in one of your expressions. One of your other expression has a more serious problem. It needs an additional set of parentheses to make it true.
Let y = x:
What this says literally is that \ \displaystyle x^{3}/(x^{2}+x^{4}) = \frac{x}{1}+x^{2}\ .
What you meant to say (I hope) is \ \displaystyle x^{3}/(x^{2}+x^{4}) = x/\left(1+x^{2}\right)\,,\ which is equivalent to \ \displaystyle x^{3}/(x^{2}+x^{4}) = \frac{x}{1+x^{2}}\ .
x^{2}/(2x^{2}
This should have been \ x^{2}/(2x^{2})\ .
If the limit along that second path was indeed undefined, then yes, that would show that the original limit does not exist.
\displaystyle \lim_{x\to\,0} \left(\frac{x^{2}}{2x^{2}}\right)\ does exist. What is it?
(It's different than the limit along the path y = x. That does show that the original limit does not exist.)
Yeah that was actually exactly what I meant but got confused in my latex-noobness :S
  • · Replies 21 ·
