Limit problem involving two circles and a line
8 replies · 2K views
member 731016
Please see below
Please see below
For this problem,
The limiting position of R is (4,0). However, I am trying to solve this problem using a method that is different to the solutions. So far I have got,
##C_1: (x - 1)^2 + y^2 = 1##
##C_2: x^2 + y^2 = r^2##
To find the equation of PQ,
## P(0,r) ## and ##R(R,0) ##
## y = \frac{r(x - R)}{-R} ##
Then solve for ## R ## to get,
##R = \frac{rx}{r - y}##
##R = \frac{rx}{r - \sqrt{r^2 + x^2}} ##
##R = \lim_{r \rightarrow 0^+} \frac{rx}{r - \sqrt{r^2 + x^2}} = 0 ##
Can someone please give guidance to what I have done wrong?
Many thanks!
What did you get as coordinates for ##Q##?
Reply
Thank you for your reply @fresh_42! I missed up finding the coordinates of ##Q## in my original attempt.
But according to the solutions,
However, I am curious how to solve this problem without using Q's coordinates.
Many thanks!
You need the equation for the line ##\overline{PQ}## which is defined by ##Q## so you definitely need the coordinates for ##Q## somehow; if not explicitly then implicitly. Say the straight is ##y=mx+b.## Then ##R## has the coordinates ##R=(-\frac{b}{m},0).## We finally need to solve ##\lim_{r \to 0^+} \frac{-b}{m}.##
I do not see how to get there without ##m## and ##b## that are determined by ##P## and ##Q.##
Reply
Hint for the limit calculation:
a) Show that the quotient is greater than ##2## for ##0<r < 2.##
b) Set the quotient equal to ##L## and solve for ##r^2.##
c) Show what happens to ##L## if ##r \rightarrow 0.##
Reply
Thank you for your replies @fresh_42!
I think part of my confusion is that I think that the line ##\overline{PQ} = \overline{PR}##. Do you please know why they are different?
I also think I wrongly wrote ##R## as ##R(R,0)##, because I was thinking that the distance from the origin to point ##R## is ##R##. I now think that is incorrect because the problem only specifies the point as ##R##. Do you please know whether that is the only reason why we cannot assume that ##R(R,0)##?
Many thanks!
Sorry, do you please know what it means to find the coordinates of ##Q## explicitly or implicitly?
Would finding the coordinates of ##Q## explicitly translate to find ##Q## as a function of some variables, for example ##R=(-\frac{b}{m},0)## like you wrote?
And finding coordinates of ##Q## implicitly would translate to ##Q## as a function of some other variables?
Many thanks!
They are not. ##P## and ##R## change when the left circle shrinks. They, and ##Q##, depend on its radius ##r.##
That is both true. ##R=(R,0).## A better notation would be ##R=(R(r),0)## as the coordinate changes with ##r.##
Many thanks!
You are almost done. You correctly calculated ##Q=\left(\dfrac{r^2}{2}\, , \,\dfrac{r}{2}\sqrt{4-r^2}\right).##
The rest is not so difficult. The equation for a line given by points ##A=(x_a,y_a)## and ##B=(x_b,y_b)## is
\dfrac{y-y_a}{x-x_a}=\dfrac{y_b-y_a}{x_b-x_a}
So calculate this expression with ##A=P## and ##B=Q,## bring it into the form ##y=m\cdot x+ b## and calculate ##R=(x_0,0)=(x_0,m\cdot x_0+b),## i.e. 0=m\cdot x_0+b## or ##x_0=-\dfrac{b}{m}=R(r).##
This gives you the ##x##-coordinate of the point ##R## as a function of ##r,## the radius of the left circle.
Then proceed along the lines in post #5 in order to find the limit mentioned in post #4.
Reply
You have computed the coordinates of ##Q##. Correctly calculated them! So you can work with these formulas, which would be an explicit use.
We need the information hidden in the position of ##Q## because it defines our problem. We need ##Q.## If you do not want to use the coordinates, the result of your calculation, then you have to use ##Q## otherwise. That would be an implicit use since you had to use the definition of ##Q## without calculating it. Such usage is called implicit use since you avoid the explicit solution. I have no idea how to do that and consider it unnecessary especially as you do have the coordinates already. I just answered your idea of doing it without knowing the coordinates.
E.g. The point ##R## is implicitly given. We know how to construct it since we have a description of the algorithm, but we do not know the explicit coordinates, yet.
Calculate them next: ##R=\left(-\dfrac{b}{m},0\right).## What are ##m## and ##b## as a function of ##r##?
Many thanks!
Reply
