Limits of trigonometric functions
10 replies · 11K views · last reply
OrbitalPower
Why do some problems return the wrong answer while others do not on the ti-89.
For example:
[tex]\[ \lim_{x \to 0} \frac{\cos\theta \tan\theta}{\theta}\][/tex]
Shows up wrong (shows up as pi over 180).
But
[tex]\[ \lim_{x \to 0} \frac{\sin x(1 - \cos x)}{2x^2}\][/tex]
does not?
Not sure, but you should be able to do these easy by hand.
Shows up wrong (ships up as pi over something).
What is the something? 3.14159...?
No. Pi/180. But that isn't one. My question is, why do certain trigonometric equations show up as the textbook answers, but not others.
For example, like I said, the second one returns correctly, the first one does not. I understand it should be in radian mode now, but why does degree mode give the right answer 50-75% of the time in my experience?
I am very confused :( These problems have nothing to do with angles! It shouldn't matter what mode you shove these into your calculator.
Right, Gib Z. That's exactly what I was thinking. Just thought it would be helpful for the forum if someone had a quick explanation.
does not?
Nothing happens to that limit as x changes, maybe that's why your calculator comes up with something different.
[tex]\[ \lim_{\theta \to 0} \frac{\cos\theta \tan\theta}{\theta}\][/tex]
For example:
But
does not?
Not wrong
[tex]\[ \lim_{x \to 0} \frac{\cos\theta \tan\theta}{\theta}= \lim_{x \to 0} \frac{\sin\theta }{\theta}=\frac{\pi}{2 \arcsin 1}\][/tex]
in degrees pi/180 deg^-1
in grad pi/200 grad^-1
in rad 1 rad^-1
in mil pi/3200 mil^-1
in clock pi/6 hours^-1
in rotations pi/.5 rot^-1
Angle measure units matter
Rad make calculus things look nice
Why use the calculator at all save that for later
Make sure your calculator is in "radian" mode rather than "degree" mode!
Yeah, thanks guys. And I think I see what you're saying lurflurf. If you convert it from degrees to randians its 1 anyway. (What's the deg^-1?)
It is from unit analysis
(10 feet)/(5 seconds)=2 feet seconds^-1
if
units(x)=degrees
units(sin(x))=1 (ie no units)
then
units(sin(x)/x)=1/degrees=deg^-1
angle measure units are not entirely well defined
but tracking them can prevent errors especially when radians are not being used
if anyone like -1 better than 2
pi/arccos(-1)=pi/(2 arcsin(1))
=limit x->0 sin(x)/x
for that matter may expressions are possible
