Is W a Subspace of All Ordered Pairs?
  • Thread starter Thread starter winter_ken
    Subspaces
W, defined as the set of all ordered pairs of real numbers with standard addition and a non-standard scalar multiplication, raises questions about its status as a subspace. It is noted that W is not a vector space, but there is a suggestion that it could be a subspace if it is closed under the defined operations. The discussion emphasizes that for W to be closed under scalar multiplication, the result of kU must still yield an ordered pair of real numbers. Additionally, the zero vector must be included in W for it to qualify as a subspace. Understanding these concepts clarifies misconceptions about the definitions and properties of subspaces in vector spaces.
winter_ken
Let W be the set of all ordereed pairs of real numbers, and consider the following addition and scalar multiplication operations on U=(u1,u2) and V=(v1,v2)
U+V is standard addition but kU=(0, ku2)
Is W closed under scalar multiplication?
I understand that W is not a vector space but my book suggests that it is a subspace closed by scalar multiplication.
Is it because kU=(k0, ku2) where k multiplies both terms?
Being closed under scalar multiplication just means that if w \in W and k \in \mathbb{R} then k w \in W.
Since W doesn't really have any restrictions, you only need to check that (0, ku2) is an ordered pair of real numbers.
Is kU \, = \, (0, ku_{2}) an ordered pair of reals ? Also, does W contain the zero vector ?
It's pretty strange to talk about subspaces here, since W isn't defined as a subset of a vector space. It's just defined as a set with two operations which may or may not turn it into a vector space.
If it turns out to be closed under both addition and (this non-standard) scalar multiplication, then you can check if it satisfies the eight vector space axioms, to see if it's a vector space.
Thanks for the help! That solves it for me completely! I thoroughly didn't understand the definitions of subspace and what they mean and represent, so this simple explanation really clears up a big misconception that I had.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
