Line Integral Problems: Solving for Work and Potential Functions
The discussion focuses on solving line integral problems involving work and potential functions. Participants seek guidance on parameterizing curves and calculating line integrals, specifically for the vector field v=xyi+x2j along the curve y=x3. A key point is the importance of expressing the curve as a vector and calculating the differential dr for integration. The conversation emphasizes the need to correctly set up the components of the vector and perform the dot product to simplify the integral. Ultimately, the goal is to demonstrate that the work done is path-independent and can be derived from a potential function.
EdisT
Thread moved from the technical forums, so no HH Template is shown.
I'm used to parameterizing however I'm not sure how to solve these types of problems, any help would be much appreciated.
1) Calculate the line integral ∫v⋅dr along the curve y=x3 in the xy-plane when -1≤x≤2 and v=xyi+x2j
2) a) Find the work that the force F = (y2+5)i+(2xy-8)j carries out along two paths ABC and ADC which are composed of perpendicular lines between the points A,B,C,D. A,B,C,D are corners in a square and the corners have the coordinates (0,0),(1,0),(1,1),(0,1) respectively
b) Calculate the work done along a straight line from A to C.
c) Since the work done appears to be independent of the path taken, we expect that the force can be written as the gradient to a potential V. Find the potential-function and show that the difference between the potential at A and C are equivalent to the work done.Attempt at reaching a solution:
1) I substituted y=x3 into the equation then did a normal integral with respect to x. It doesn't seem right to me however I'm used to dS and t so these problems just messed my thinking up.
2) Similar thinking to 1) is messing me up I think. Did normal integrals with respect to x and y.
Here, r is a vector between the origin and a point (x,y) on the curve y = x3.
Do you know how to set up the components of the vector r to describe y = x3 ?
Once you find r, you can calculate dr and substitute into the line integral expression. After calculating v ⋅ dr, then you can start to treat the line integral like a regular integral.
Likes EdisT
No I have no idea how to split it up, the dot product should be easy enough but I'm more used to x(t), y(t) being given.. How would you split it up?
Do you know how to decompose a vector into its components?
Likes EdisT
It's been a while... I don't quite remember
You can look up how on the internet. That's what it's for.
Remember, i, j , and k are the unit vectors for a general vector r, such that r = x i + y j + z k
You have a curve described by y = x3. Care to take a guess as to how this curve could be turned into a vector expression?
Likes EdisT
r=x^3i+yj ?
EdisT said:
r=x^3i+yj ?
What's the independent variable in y = x3 ?
Likes EdisT
x would be the independent variable, so it would be x^3j?
Correct. r = x i + x3 j + 0 k
Can you calculate dr now?
Likes EdisT
dr = (i + 3x2) dx
The dot product would be v⋅dr = xy+3x4 dx
The integral would then be: ## \int_{-1}^2 xy+3x^4 \, dx ## ?
EdisT said:
dr = (i + 3x2) dx
Don't forget the j component for the 3x2.
What does y equal when traversing the curve y = x3 ?
Likes EdisT
SteamKing said:
Don't forget the j component for the 3x2.What does y equal when traversing the curve y = x3 ?
Of course, the integral becomes x^4+3x^4 dx. thank you!
  • · Replies 20 ·
