Calculating Line Integral in xy-Plane
To calculate the line integral of the vector field v = xy i + x² j along the curve y = x³ from x = -1 to x = 2, the parameters x and y are set as x = t and y = t³. The differential vector dr is derived as dr = dt i + 3t² dt j. The integral is expressed as ∫ v ⋅ dr, leading to the formulation ∫ (t³ dt + 3t² t² dt) from -1 to 2. The final result of the integral calculation is 25.25, although there is a noted discrepancy when comparing this value to the area under the curve between x = 1 and x = 2.
KUphysstudent
Calculate the line integral ° v ⋅ dr along the curve y = x3 in the xy-plane when -1 ≤ x ≤ 2 and v = xy i + x2 j.
Note: Sorry the integral sign doesn't seem to work it just makes a weird dot, looks like a degree sign, ∫.2. The attempt at a solution
I have to write something along with the calculations for exams so I do that here as well, it is probably not correct.
parameterize x and y in terms of t because we need to take the integral of the dot product of the position vector dr with the vector field v. In this case we can say that x = t which in return gives us y = x3 = t3. Now taking the derivative with of x and y with respect to t, dx/dt = 1 dy/dt = 3t2 which we can put into the equation for dr, which is dr = dx i+ dy j+ dz k → dr = 1 dt i+ 3t2 dt j + 0 dt k
insert in (integralsign)∫ v ⋅ dr → (integralsign)∫ xy i+x2 j ⋅ 1 i+ 3t2 j , with the lower bound of integration being t = -1 and the upper bound t = 2.
The dot product of [a, b, c] ⋅ [d, e, f] = [ad, be, cf]. therefore (integralsign)∫ v ⋅ dr = xy + x21 dt i+ 3t2 dt j = xy dt + 3t2 x2 dt
3. Relevant equations
But now I'm completely lost and don't understand what I'm supposed to do with x's and y's, shouldn't they have been in terms of t's as well? My book has one example which is much easier than this one since the vector field is just v = yi in that one.
Anyone who can teach me what to do please let me know.
Do I just substitute xy and x2 with my parameter x = t and y = t3, so I get xy = t3 and x2 = t2 → (integralsign)∫ t3 dt + 3t2 t2 dt ?
Yes. Everything you have done looks correct so far except for your final substitution. You have the right idea, but check for errors.
if you calculate the integral with this step, (integralsign)∫ t3 dt + 3t2 t2 dt from -1 to 2 you get 25.25
I forgot to add that if you graph y=x^3 and look at the area between x = 1 and x = 2 it looks like it adds to about 4, which is quite a bit away from 25.25
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 23 ·
